Best oil Mobil 1 High mileage for 93 deville 4.9 with 102,000 miles
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 30
Like Tree1Likes
HT4100 4.1, 4.5, 4.9 Discussion, Best oil Mobil 1 High mileage for 93 deville 4.9 with 102,000 miles in Cadillac Engine Discussion; Hi everyne sorry to bother you guys again I just wanted to know if i should switch oil to Mobil ...
    mike93 is offline Cadillac Owners Fanatic
    Automobile(s): 1993 Cadillac sedan deville
    Sep 2009
    Media, Pennsylvania
    25
    281
    SmileBest oil Mobil 1 High mileage for 93 deville 4.9 with 102,000 miles
    Hi everyne sorry to bother you guys again I just wanted to know if i should switch oil to Mobil 1 High mileage I know mobil 1 is the best and wanna put the best oil in my car so do you think I should put mobil 1 I would pay the extra money to go with the best I want my car to last me a long time it only has 102,000 miles on it thanks everyone.
    Dave S Texas's Avatar
    Dave S Texas is offline Cadillac Owners Enthusiast
    Automobile(s): '87 Coupe DeVille 4.1L FWD(New engine '08) 1981 F100 '03FXDL
    May 2008
    Austin(area), Tx
    73
    876
    Re: Best oil Mobil 1 High mileage for 93 deville 4.9 with 102,000 miles
    M1 is a very good oil. Just follow manufacturers recommendation. More important is the oil filter. I use only Purolator or Wix, never any other brand, and change it at 3k miles. Using a syn oil: you can go longer than when using dino-oil, but the filter still changes at 3k.
    drewsdeville is offline Cadillac Owners Master
    Automobile(s): 2011 Crown Vic LX, 2009 Chevy Malibu 2LT
    Oct 2004
    Oak Creek, WI
    5,609
    I don't use mobil 1, but I was told by a frequent user that mobil 1 filters are spec'd to last as long as the synthetic mobil 1 oil interval. Might be something to look into for less hassle.
    I believe most regular oil filters are good for up to 7500 miles now...
    68
    81,897
    This has been beaten to death so many times. There is no "best" oil. One is as good as the next. No oil will cause an early failure. "Best" is in your mind and the manufacturers marketing. They know that people are passionate about their cars and spend a lot of money trying to convince us that their oil is the "best" for our babies. Use the cheapest oil you can find or the most expensive and your engine life will be the same. Your engine does not need synthetic. If you feel better about using it, then by all means do so. ALL oils today are semi synthetic.
    Sep 2009
    Media, Pennsylvania
    25
    281
    Ok Ranger Im gonna put in Rotella 15W40 ive heard it's really good oil and works well and is good for the 4.9 and the distributor gear because it's thicker and has more anti-wear additives i have this at work i work at sears and it's only 3.99 a quart not that expensive so im going to use that instead.
    68
    81,897
    Good choice.
    Sep 2009
    Media, Pennsylvania
    25
    281
    ok ranger thanks another question car stumbles while accelerating i changed the tps and my mechanic did't adjust it rite could that make the car stumble and also the car goes ito like automatic cruise control when i jus give it a little gas could that be from the tps not being adjusted properly?
    68
    81,897
    I saw that thread. I'm not sure.
    Sep 2009
    Media, Pennsylvania
    25
    281
    ok thanks ranger
    Sep 2009
    Media, Pennsylvania
    25
    281
    Is it really okay to use rotella in the 4.9 ranger it's not too thick rite ive heard stories about it maybe being to thick maybe idk i just wanna help the distributor to help keep it lubricated and take a little off the load.
    68
    81,897
    It's perfectly fine. It was recommended by our old Guru, a GM powertrain engineer. Can't get a better recommendation than that.
    Sep 2009
    Media, Pennsylvania
    25
    281
    ok thanks ranger sorry for being a pain i just read something on another website and it said about being to thick of an oil with pressure i can make the oil filter burst off and all this crap but if a powertain engineer said it's great then i believe it like you said can't get any better then that.
    68
    81,897
    Where do they come up with this crap?
  16. #14
    Aron9000's Avatar
    Aron9000 is offline Cadillac Owners Master
    Automobile(s): Past: 95 Fleetwood, 91 Brougham. Now: 92 Lexus SC300
    Jul 2008
    Nashville, TN
    5,418
    Since when is 103k high mileage?????
    Bigfoot9878 likes this.
  17. #15
    Sep 2009
    Media, Pennsylvania
    25
    281
    On caddyinfo.com it talk about the rotella good and the bad like oh it can make the motor wear out quicker and about the oil filter blowing off ranger so that's the website that talk about that crap ranger.
  18. Remove Advertisements
