91 Deville 4.9 with no power- Need Help
Results 1 to 12 of 12
HT4100 4.1, 4.5, 4.9 Discussion, 91 Deville 4.9 with no power- Need Help in Cadillac Engine Discussion; My 18 year old son has a 91 Deville with the 4.9L engine. Last week it suddenly began running bad, ...
    rpurdy is offline Cadillac Owners Member
    Jul 2004
    5
    My 18 year old son has a 91 Deville with the 4.9L engine. Last week it suddenly began running bad, and lost so much power that it seems like it's a 4 cyl. There are no trouble codes set. We've tested the TPS and the ISC, checked and reset the base timing, replaced the plugs, wire, cap and rotor, checked the EGR valve and replaced a marginal (when tested) Oxygen sensor. I don't see any evidence of an intake leak, or evidence of blown head gaskets. The plugs we removed were pretty "sooty", so it appears to be running rich. Anybody have any suggestions on what to look for next?? I have 2 other Cadillacs, one with a 4.1L and one with a 4.5L, over 200K on each and have never had any problems like this.
    Thanks in Advance for any suggestions!
    LacSeville's Avatar
    LacSeville is offline Cadillac Owners Enthusiast
    Nov 2003
    Russellville, AR
    32
    730
    Re: 91 Deville 4.9 with no power- Need Help
    exhaust restriction. bad cat? if there was a leaky injector, it could have burnt up the cat. my 2c.
    Stoneage_Caddy's Avatar
    Stoneage_Caddy is offline Cadillac Owners 10000+ Posts
    Automobile(s): 01 frontier , 89 Shelby CSX vnt
    May 2003
    Undisclosed location in FL
    14,607
    fuel pressure regulator ?
    tacoma's Avatar
    tacoma is offline Cadillac Owners Fanatic
    Automobile(s): 1983 ElDorado
    Nov 2003
    Tacoma, WA
    51
    125
    bbq cat yum!
    2-tone is offline Cadillac Owners Member
    Jul 2004
    7
    checkyour injector fueses. one may be blown.
    Jul 2004
    5
    Thanks for your quick replies!
    The cat. convert is only about 8 mos. old, and it seems to have good flow at the tail pipe. The injectors meter resistance ok, and there is good fuel pressure. This car has always idled a little rough compared to the 87s, but I've had others tell me that's normal for the 4.9. It has always run great, it's quick and it was getting great mileage on highway trips-20 to 24mpg. To me it seems like the timing is waay retarded or there is a massive vacuum leak. How do you test for a leaking intake gasket, I understand that is a problem on 4.9s? Also, how durable is the timing chain? Have these ever jumped a tooth or two? Right now it is idling smoothly but you have to stomp it to get up the driveway.
    barbiedeville is offline Cadillac Owners Member
    Nov 2004
    ANCHORAGE ALASKA! YAY!
    33
    26
    try a new cadilidic converter (did i spell that right? ahah) ..they get all plugged up over the years...i had the same problem
    onecool is offline Awaiting Email Confirmation
    Automobile(s): Deville
    Dec 2005
    288
    check passanger side relay center 15 amp fuse
    HUF's Avatar
    HUF
    HUF is offline Cadillac Owners Connoisseur
    Automobile(s): 1995 FWB 118,*** miles
    Dec 2005
    MA
    58
    2,129
    TalkingRe: 91 Deville 4.9 with no power- Need Help
    Quote Originally Posted by barbiedeville View Post
    No. It's catalytic. Geez! I have just googled "cadilidic" and that spelling appeared to be so popular!
    cadillac_al is offline Cadillac Owners Connoisseur
    Automobile(s): 70 Deville 77 Fleet 78 Seville 92 Deville 03 Deville
    Feb 2007
    Maine
    55
    3,310
    I'll bet this car has been scrapped by now
    69
    82,382
    Nothing like answering a 5 yr old thread.
    steelybill is offline Cadillac Owners Enthusiast
    Automobile(s): '85 Fleetwood FWD
    Mar 2009
    mich
    85
    728
    :d:d:d
  15. Remove Advertisements
