Go Back   Cadillac Owners Group > General Discussion > Cadillac Engine Technical Discussion > HT4100 4.1, 4.5, 4.9
HT4100 4.1, 4.5, 4.9 This forum is to discuss the newer aluminum block Cadillac engines.
Cadillac Forums: 91 deville service engine soon
Old 07-07-09, 09:37 PM
Cadillac(s): 91 sedan deville
View cole bechtold's Photo Album
Casino Cash: $285
i have a 91 cadillac deville and the service engine soon light recently came on and it started running a little rough and my fuel economy is going down. i think it is the O2 sensor but i am not sure. i checked the codes and it said e48. what does that code mean?
  #2 (permalink)
Old 07-07-09, 11:21 PM
HUF's Avatar
HUF HUF is offline
Cadillac(s): 1995 FWB 87,*** 1991 Seville 175,000 SOLD
View HUF's Photo Album
Casino Cash: $15207
Re: 91 deville service engine soon
EGR system fault. Two EGR tubes inside the throttle body under the blades are probably clogged with carbon. Clean them up with a piece of coat hanger and you will most likely be fine. Do not care of chunks of carbon falling down. While there use some oxygen sensor safe carb cleaner to clean the bores and the BACK sides of the blades. After cleaning disconnect the negative cable for a minute to reset the computer to default values (clean throttle body bores and blades).
  #3 (permalink)
Old 07-08-09, 12:36 PM
View Ranger's Photo Album
Casino Cash: $24216
This will tell you the DTC definitions as well as how to clear them.
http://myweb.accessus.net/~090/dtcobd1.html
  #4 (permalink)
Old 07-12-09, 03:04 PM
Tailfin's Avatar
Cadillac Owners Enthusiast
Cadillac(s): 1997 Cadillac Deville
View Tailfin's Photo Album
Casino Cash: $595
I've seen a number of these cars with both tubes completely clogged and do not throw that code. There is the EGR valve, located near the fuel rail toward the driver side, and the EGR vacuum solenoid, which is nearby and has vacuum hoses going to the throttle body. Do clean the tubes, practically every one of these engines needs that, but those are your alternatives if it sticks around.
  #5 (permalink)
Old 07-12-09, 04:33 PM
Cadillac(s): 1990 Seville
View Sevillian273's Photo Album
Casino Cash: $9328
I second that.
I ran a block-off plate in place of the EGR valve for a few thousand miles with no codes or any other issues. Its the same no-flow condition that blocked tubes would cause.
  #6 (permalink)
Old 07-12-09, 08:02 PM
Cadillac(s): 1985 Sedan DeVille
View ehall's Photo Album
Casino Cash: $10282
I used to get intermittent SES light on my '85 and it was traced to jumpy O2 readings, which was ultimately traced to a crack in the throttle body.
deville, engine, service
