Go Back   Cadillac Owners Group > General Discussion > Cadillac Engine Technical Discussion > HT4100 4.1, 4.5, 4.9
HT4100 4.1, 4.5, 4.9 This forum is to discuss the newer aluminum block Cadillac engines.
Cadillac Forums: 90 SDV Repeated E22 TPS Code
Old 07-02-09, 10:34 PM
Cadillac(s): 90 Deville
View rstewart65's Photo Album
Casino Cash: $415
I have a 90 SDV that has had repeated E22 TPS codes since the day I got it 3 years ago. I've replaced the TPS and adjusted it several times, but the light keeps coming back. After getting disgusted recently with the TPS and a semi-functional ISC, I was at the local U-Pull-It and saw a pristine 90 SDV. $25 later I had the entire throttle body with all the lines attached, etc. Took it home, cleaned it up, put it on, and it purrs like a kitten, except the E22 code keeps setting. Well, I now believe it must be a wiring issue. I have the Factory Service Manual and a Haynes and see there is a connection somewhere on the firewall between the engine compartment and interior, any idea where it might be? Any other ideas as to where I could be having a wiring issue? Any know trouble spots in teh wiring? I intend to pull the ECM and clean the connections there and have at the TPS several times already. Thanks for any info!
  #2 (permalink)
Old 07-03-09, 11:48 AM
Cadillac Owners Enthusiast
Cadillac(s): 1990 Seville
View Sevillian273's Photo Album
Casino Cash: $8923
Re: 90 SDV Repeated E22 TPS Code
Try a junkyard ECM. If its running and driving fine, then the computer is getting the necessary input from the sensor.
code, e22, repeated, sdv, tps
