| HT4100 4.1, 4.5, 4.9 This forum is to discuss the newer aluminum block Cadillac engines. | Cadillac Forums: 92 4.9 starter replacement
07-02-09, 05:53 AM
| | Cadillac Owners Member Cadillac(s): 1992 DeVille, 89 Brougham D'elegance | | Join Date: Feb 2009 Location: DePue, IL Age: 30 | | | 92 4.9 starter replacement I just replaced the starter in my 92 deville. It kind of engages and clicks. It sounds to me like it's binding up. I assume I need to shim it. Would I use a standard feeler guage for this? How do I make the starter gear engage the flywheel without turning the key or apply a current to the starter. I know that would not be a good idea. I bought a duralast starter from autozone if that makes any difference. Thanks. |
07-02-09, 01:08 PM
| | Cadillac Owners Fanatic Cadillac(s): '85 FWD fleetwood, '93 fleetwood Bro | | Join Date: Mar 2009 Location: mich Age: 78 | | | Re: 92 4.9 starter replacement Shims are common on some GM cars, like a few Chevys I've had. The Caddy doesn't have access to the starter nose to check the teeth engagement does it? I know mine doesn't. You might pick up a shim kit and try a thin shim to begin with, and see how it works. |
07-04-09, 06:26 AM
| | Cadillac Owners Member Cadillac(s): 1992 DeVille, 89 Brougham D'elegance | | Join Date: Feb 2009 Location: DePue, IL Age: 30 | | | Re: 92 4.9 starter replacement Thanks, I picked up a GM starter shim set from O'rielly's and I'm going to work on it today. And no, there's no access that I can see on the starter. |
07-04-09, 05:56 PM
| | Cadillac Owners Member Cadillac(s): 1992 DeVille, 89 Brougham D'elegance | | Join Date: Feb 2009 Location: DePue, IL Age: 30 | | | Re: 92 4.9 starter replacement This is great! That GM shim pack I bought doesn't fit. It's raining and I have no car. |
07-04-09, 07:19 PM
|  | Cadillac Owners Enthusiast Cadillac(s): 1992 Sedan Deville, 1984 Lincoln Town Car | | Join Date: Jan 2005 Location: Hawaii | | | Re: 92 4.9 starter replacement Quote:
Originally Posted by sideshowbob I bought a duralast starter from autozone if that makes any difference. Thanks. | Take the starter back to them and throw a full blown tantrum at the top of your lungs in front of as many customers as possible, until they give you a starter that works. This is the second AUTOZONE horror story of the day for me. The other thread was an autozone fuel pump he had to replace after only 6 weeks of operation. These people should be out of business for all the crappy parts they sell to honest law abiding citizens.  |
07-05-09, 08:43 PM
| | Cadillac Owners Fanatic Cadillac(s): 1993 Eldorado, 4.9L, 200k miles | | | | | Re: 92 4.9 starter replacement The starter should include an information sheet that describes the shimming process and procedure. If memory serves me correctly, shims need to be added to 1 of the mounting bolts, or the other, depending on the sound emitted during starting (i.e. shimming 1 of the bolts moves the starter's nose closer to the ring gear....shimming the other bolt mores the starter's nose away from the ring gear) |
07-07-09, 02:38 AM
|  | Cadillac Owners Fanatic Cadillac(s): 91 sedan deville | | Join Date: Jan 2007 Location: san antonio, tx Age: 26 | | | Re: 92 4.9 starter replacement Your problem is the autozone starter, I had the same problem and replaced it with another starter from autozone. I'll let you in on a little secret. If you need the starter to test out bad take the solenoid apart and remove some parts or cut the wires on the inside. Then put it back together and when the scam artist at autozone try to test it it wont come on therefore it will test bad. Because trust me if you test it the way it is right now, at autozone, I guarantee it will work and they'll make you think there's something wrong with your car. Another important thing is never buy electronic parts from autozone, I guarantee you will be replacing it again and again. |
07-07-09, 05:07 AM
|  | Cadillac Owners Enthusiast Cadillac(s): 1992 Sedan Deville, 1984 Lincoln Town Car | | Join Date: Jan 2005 Location: Hawaii | | | Re: 92 4.9 starter replacement TV should have a new horror series titled "Autozone" - like Twilight only real  |
07-07-09, 04:07 PM
|  | Cadillac Owners Member Cadillac(s): 83 Eldorado, 90 Seville 94 Concorse | | Join Date: Jun 2009 Age: 54 | | | Re: 92 4.9 starter replacement Quallity remanufactured out of country parts?  Go figure. By the way the problem is'nt limited to just AZ.  Your better off buying GM. It will cost more, but you only have to do the work once.  |
07-09-09, 01:02 AM
|  | Cadillac Owners Fanatic Cadillac(s): 91 sedan deville | | Join Date: Jan 2007 Location: san antonio, tx Age: 26 | | | Re: 92 4.9 starter replacement "TV should have a new horror series titled "Autozone" - like Twilight only real" Amencaddy.
Nice I would watch it  |
07-09-09, 01:11 AM
Originally Posted by revdowrong "TV should have a new horror series titled "Autozone" - like Twilight only real" Amencaddy.
Nice I would watch it  | i think SciFi came up with it. Did you see the series premiere last night "Warehouse 13"? LOL! I thought they probly have a lot of A-zone parts in there. | | Cadillac Discussion Tools | | |
Censor is ON | | | |
