Hub on crankshaft
Results 1 to 5 of 5
HT4100 4.1, 4.5, 4.9 Discussion, Hub on crankshaft in Cadillac Engine Discussion; hey all i finely got the hub off my crankshaft now when i press this on should i lube the ...
    tacoma's Avatar
    tacoma is offline Cadillac Owners Fanatic
    Automobile(s): 1983 ElDorado
    Nov 2003
    Tacoma, WA
    51
    125
    QuestionHub on crankshaft
    now when i press this on should i lube the outside of this hub
    where it contacts the front oil seal? theres some slight grooving
    on the hub but i think its ok
    tia
    BeelzeBob's Avatar
    Dec 2002
    Fort Lauderdale, Florida
    52
    9,577
    Re: Hub on crankshaft
    Polish any scoring or grooving in the hub wiht some 600 sandpaper and clean up the surface thoroughly afterward.
    It is a good idea to pack some grease between the front seal lips before installing the hub. Lube the inside and outside of the hub with engine oil when you install it. Pull the hub on with a threaded installer....not a hammer.
    tacoma's Avatar
    Nov 2003
    Tacoma, WA
    51
    125
    great thx bbob front of hub looks like someone did use a hammer
    i have the correct threaded installer so im good to go on that
    thanks again
    kadillak kid is offline Cadillac Owners Member
    Oct 2010
    36
    were did you get instiller
    Feb 2003
    california
    69
    6,680
    You can get a sleeve called a "speedy sleeve" for most engines that will provide a non grooved surface that slips over the hub, check to see if they make one for your engine.
  8. Remove Advertisements
