Go Back   Cadillac Owners Group > General Discussion > Cadillac Engine Technical Discussion > HT4100 4.1, 4.5, 4.9
HT4100 4.1, 4.5, 4.9 This forum is to discuss the newer aluminum block Cadillac engines.
Cadillac Forums: Changing belts on 84 deville
Old 12-07-08, 09:13 PM
Cadillac(s): 1984 Cadillac Deville
View sshobe's Photo Album
Casino Cash: $310
I have a 84 deville with the 4.1 in it.... the lower V belt busted and I am trying to replace it but cannot figure out where to release the tension to fit the belt over the pulleys.
This is the lower belt itting over three pulleys and I believe the tension release is on the ac compressor, but short of removing the unit I cannot figure out where to loosen the tension at
  #2 (permalink)
Old 12-07-08, 11:51 PM
Dave S Texas's Avatar
Cadillac Owners Enthusiast
Cadillac(s): '87 Coupe DeVille 4.1L FWD(New engine Dec '08)
View Dave S Texas's Photo Album
Casino Cash: $9645
Re: Changing belts on 84 deville
On my '87 DeVille/4.1L, there is one surpentine belt running everything. The tension release is attached to the power-steering unit and requires a 1/2" breaker-bar to operate it.
  #3 (permalink)
Old 12-08-08, 03:09 AM
Casino Cash: $310
My 84 has three belts.... one going from the alt to the fan, one going from the main engine pulley to the fan then to what I believe is the AC compressor, and then one going from the main to a pump on the top... the second one I mentioned is the one that broke and I am trying to replace.
I need to figure out how to loosen the AC compressor which is where I believe the tension settings is for the belt
  #4 (permalink)
Old 12-10-08, 08:30 PM
Cadillac(s): 1988 Allante' (sold), 1984 Eldorado 4100 91 Allante
View carnut's Photo Album
Casino Cash: $8195
Loosen all bolts securing the compressor. There is a long threaded bolt behind the compressor angled to the right and up. Once ALL bolts are loose, tuning that bolt counter clockwise should allow the compressor to drop. Me thinks not ALL bolts are loose. Make sure you get the smog pump belt very tight or the alternator will slip on the water pump pulley causing a weak or dead battery over time.
Tags: ,
belts, changing, deville
