92 seville 4.9L engine problem
Results 1 to 9 of 9
HT4100 4.1, 4.5, 4.9 Discussion, 92 seville 4.9L engine problem in Cadillac Engine Discussion; ...
    Tammy is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Nov 2008
    Hi,
    I´m from Argentina and I own a 1992 Cadillac Seville (L26 4,9L). I am having some problems with the car, and perhaps someone in this forum can help me find the possible causes and solutions.
    The problem is that when the engine is running, after a few minutes, it starts to vibrate, lose power and produce white smoke –which comes out through the exhaust and also directly out of the engine. The smoke is very dense and makes eyes burn, so its not water vapor.
    I think it’s an electronic problem, because when this happens, I stop the engine and wait for a couple of minutes; after that I start it again and it works normally for a few minutes until the problem happens again.
    I know that to identify the problem I need to use the Tech 2. I have the Tech 2 but the problem is I dont have the card software or the plug adaptor for the Seville model.
    I hope someone here can tell me if they´ve had this problem or suggest where I can buy these diagnose tools (Card software and plug adaptor).
    Thank you in advance!
    Best,
    Tammy
    cadillac_al is offline Cadillac Owners Connoisseur
    Automobile(s): 70 Deville 77 Fleet 78 Seville 92 Deville 03 Deville
    Feb 2007
    Maine
    55
    3,310
    Re: 92 seville 4.9L engine problem
    If you are positive it is not losing coolant, it might be the catalytic converter doing something funny. At the top of this 4.9 section there is a sticky with instructions on getting your codes. Try that and see what comes up.
    HUF's Avatar
    HUF
    HUF is offline Cadillac Owners Connoisseur
    Automobile(s): 1995 FWB 100,*** miles CURRENT. 1991 Seville 175,000 SOLD
    Dec 2005
    MA
    58
    2,117
    donwon is offline Cadillac Owners Enthusiast
    Automobile(s): 92 Deville
    Sep 2004
    SC.
    548
    If it was an origional USA car, Check the PCV valve. If it don't rattel change it.
    NickySantoro is offline Cadillac Owners Fanatic
    Automobile(s): 1993 Eldo 4.9 66K miles
    Nov 2005
    Nazi Jerky, libtard central
    368
    White smoke might be a sign that the vacuum modulator on the transmission has failed and transmission fluid is being pulled into the intake. This is simply checked by removing the vacuum line at the modulator and inspecting for the presence of fluid. There should be none.
    Nov 2008
    Thank you all for your help! I,m going to try with these solutions. I,ll let you know what happens!
    Best,
    Tammy
    justin4yu is offline Cadillac Owners Member
    Automobile(s): 1992 Cadillac Fleetwood 2door sedan
    Jun 2010
    Yelm, Washington, United State
    31
    31
    I had a problem with a injector not working, I found a computer out of a wrecked car for $10 bucks, switched proms and it runs on all eight now, i think you might try that and see if it works. It sounds to me you have injectors firing randomly causing your white smoke maybe I am wrong.
    69
    82,163
    This thread is 2 1/2 yrs old. I'd guess it is fixed, junked or sold by now.
    Jun 2010
    31
    31
    TalkingRe: 92 seville 4.9L engine problem
    I did not realize how old the thread was, thank you for bringing that to my attention, i still think its helpful for the next guy with the same problem looking thru the forum.
  12. Remove Advertisements
