Cam position sensor replacement
Page 1 of 2 12 LastLast
Results 1 to 15 of 17
HT4100 4.1, 4.5, 4.9 Discussion, Cam position sensor replacement in Cadillac Engine Discussion; How do you change it, the mounting plate for the rotor button is RIGHT in the way....
    79malibuonblocks is offline Cadillac Owners Member
    Automobile(s): 1984 coupe deville 4.1 67,000original/1991 sedan deville 4.9
    Oct 2008
    85
    Sevillian273's Avatar
    Sevillian273 is offline Cadillac Owners Connoisseur
    Automobile(s): 69 Thunderbird | 90 Seville | 89 Marquis | 72 Torino
    Oct 2008
    Palm Bay, FL
    2,024
    Re: Cam position sensor replacement
    I beleive I used a 1/4'' socket by itself and gripped the socket with a small pair of pliers.
    kdcing is offline Cadillac Owners Fanatic
    Automobile(s): 1993 Eldorado, 4.9L, 200k miles
    Dec 2006
    273
    You are referring to the sensor in the distributor, underneath the ignition rotor...correct? If yes, the distributor must be removed from the engine. Remove the roll pin holding the gear onto the bottom of the shaft by punching it out w/ a punch...then, I believe the bottom of the distriutor slides off freeing the sensor.
    Oct 2008
    85
    Quote Originally Posted by kdcing View Post
    thats what i figured
    Oct 2008
    85
    Quote Originally Posted by Sevillian273 View Post
    i cant even get the socket under the mounting plate by itself
    Oct 2008
    Palm Bay, FL
    2,024
    I beleive kd is referring to the pick-up coil which encircles the distributor shaft in the bottom of the housing. You DO NOT need to remove the distributor to change the cam sensor. Trust me, Ive done it already. You just have to get creative with different tool combinations. Ive attached a picture of the sensor itself so everybody is on the same page. I cant remember 100% how I got mine outsince it was almost a year ago. It was either with a small socket or a T-25 or 20 torx bit and a pair of pliers. Grind the socket smaller if you can....
    gdwriter's Avatar
    gdwriter is offline Cadillac Owners 10000+ Posts
    Automobile(s): 2010 CTS (Elvis) 1964 Impala (Betty) 1991 Miata (Dolly)
    Aug 2005
    Independence, OR
    50
    14,315
    I've changed mine out twice without removing the distributor. I couldn't figure out how to get a socket in there, but with an open-end 1/4" wrench, persistence and a lot of cuss words, I got it done. And I have very limited mechanical ability.
    Dec 2006
    273
    Good catch...I was referring to the round/doughnut-shaped pickup coil in the bottom of the distributor.
    If it you need to remove the sensor shown in Sevillian's e-mail, then I yield to his experience as I do not have experience and do not recall seeing that sensor in my '93 Eldorado's 4.9L distributor.
    Oct 2008
    85
    That is the culprit! I tried an open end but with no luck. I wonder if they make a 1/4 inch offset wrench like a distributor wrench? That would be ideal......if not i suppose i will have to sacrifice a socket.
    Oct 2008
    85
    i found a real short box end 1/4 wrench and FINALLY got her offa there! I did notice some play in the distributor tho..............
    Oct 2008
    Palm Bay, FL
    2,024
    Good to hear that 79. Did the car run any better? Kdcing, you do indeed have a cam sensor in your 4.9. In fact I used a FSM for a 1993 4.9 to diagnose mine... ended up being the ECM.
    Oct 2008
    85
    yea 273.......seems that the cam sensor AKA. "hall effect switch" is in the distributor, i changed it, no more spittin and sputterin......i thought most cam sensors were on the block, leave it to cadillac! But i looked at that damn diagram, and it was above my head man. So I figured if cam sensor do no good then i change the computer.....its all just $$$$$.lol
    Dec 2006
    273
    Since I've already replaced so much crap in my car, I certainly hope to not have to go back into the depths of my distributor. Thanks for the tips if I do find the need to dive in there!
  16. #14
    Joseppi is offline Cadillac Owners Member
    Automobile(s): 1993 Sedan DeVille
    Aug 2010
    1
    While I've found answers to some questions in this forum in the past, I just registered today so I could provide some information on this subject that might be helpful to others. This information might already be here somewhere, but I didn't find it so I hope this helps someone else sometime.
    Recently the "Service Engine Soon" light came on so I took my car to a friend (retired ASE - GM mechanic) who changed the plugs, plug wires, distributor cap, and rotor. After all this, the service light stayed on but the car started choking. So, he then replaced the EGR; but the service light still stayed on and the car seemed to get progressively slightly worse. Not terrible, but not as good as before the tune-up.
    Searching the 'net, I learned how to check the on board computer and from that I learned that E41 meant a cam sensor problem.
    So, I found another shop to replace that and then the service light went out and the car ran great again ... for about one day, then the same problem came back. So, I took the car back and the replaced the cam sensor again (no charge -- good shop) and this time put some added insulation on the wires that attach to the cam sensor because the suspected that the wires may have shorted out and caused the new cam sensor to fail.
    Now, my favorite old car runs fine again.
    Just thought that this additional information might be helpful.
    BTW: The cam sensor part number is:
    WELLS DR179 -- $64.79 -- ($125 installed total).
    (PS: I would have inserted a photo of the cam sensor, but couldn't find a way to do that here.)
  17. #15
    daniel58 is offline Cadillac Owners Fanatic
    Automobile(s): 58 Coupe Deville, 77 Coupe deville, 90 Deville
    Sep 2009
    183
    So the cam sensor fixed the problem, sputtering and running bad in general? My 90, 4.5 has the same symptons, but no codes, I was told that the car would not run with a bad cam sensor, yours did but with a code set? I have replaced everything else in my 90 except the cam sensor and this sensor checks out per the (olming out) FSM tests. The Recluse is telling me that these things can fail in use even if they do check out, I'm wondering??? I have so much in this car now I hate to throw good money after bad. Trip to the junkyard in my future I guess.
  18. Remove Advertisements
