Harmonic balancer 83 Fwd In-Line 4.1
Results 1 to 6 of 6
HT4100 4.1, 4.5, 4.9 Discussion, Harmonic balancer 83 Fwd In-Line 4.1 in Cadillac Engine Discussion; ok my harmonic balancer and pulley are fastened by 4 screws take them off then the pulley, harmonic ballancer pull ...
    tacoma's Avatar
    tacoma is offline Cadillac Owners Fanatic
    Automobile(s): 1983 ElDorado
    Nov 2003
    Tacoma, WA
    50
    125
    QuestionHarmonic balancer 83 Fwd In-Line 4.1
    then the pulley, harmonic ballancer pull right off and im left with a keyed hub
    pressed onto crankshaft i can tell this hub is going to be a tough one to
    remove my question is on installing do i need the same bolt as suggested in
    other topics m18 x 1.5 by about 3.5 inches and presently mine has no bolt
    securing it in the middle is there supposed to be one or is this press fit only?
    could it hurt to put one in there?
    and on another note should i replace my fan with one without a cluch on it?
    thanks again
    upon further examination im thinking it might be a m16x2.0 but i still dont know
    qwerty111 is offline Cadillac Owners Member
    Dec 2003
    19
    Re: Harmonic balancer 83 Fwd In-Line 4.1
    I had the same question about reinstalling the hub on the crankshaft after replacing my timing gears and chain. I followed the book and just reinstalled it assuming it was a press fit. My crankshaft didn't have any threads in it to use a bolt. After about 300 miles I was rechecking the belt tightness and looking for oil leaks around the timing cover when I noticed the lower pulley was almost off of the crank. I would up drilling and tapping the crankshaft to install the bolt and GM washer to keep the damn thing together. Scared the beejammers out of me considering the damage that pulley would have wrought if it flew off. I would recommend installing the bolt and go to GM to get the correct washer for it. Regular washers won't work properly. Just my experience.
    tacoma's Avatar
    Nov 2003
    Tacoma, WA
    50
    125
    thanks for the reply
    all the info ive seen just shows a cork to cover the hole
    and no mention of a bolt or thread pitch im still thinking
    the m16x20 threads but i havent got that far yet :rolleyes2
    heres a pic
    BeelzeBob's Avatar
    Dec 2002
    Fort Lauderdale, Florida
    52
    9,577
    The hub is a press on item. The press alone should be fine. If a hub comes loose it must not have been fully pressed on.... The cranks were all threaded for a puller to install the hib in service to my recollection. The cork was just stuck into the threads to keep dirt out. It is amazing how long those little corks will stay in there...LOL
    You can add a bolt to hold the hub if you like but it really shouldn't be necessary if you use the proper threaded puller to install the hub onto the crank.
    tacoma's Avatar
    Nov 2003
    Tacoma, WA
    50
    125
    o yeah its on there allright lol
    would you know what size bolt fits that so i can make a installer bbob?
    the big metric size on installers ive been seeing is m16x20 does that sound right?
    kadillak kid is offline Cadillac Owners Member
    Oct 2010
    36
    any body find out what size bolt this is
  9. Remove Advertisements
