Trying to help my girlfriends brother fix his 89 Deville and got codes, the original problem was the engine idles very high and would completely die out on him sometimes. I am not sure if the computer is bad and would cause the other codes or if the isc control/tps is actually bad as well. Thanks in advance for any help
E26 - Shorted Throttle Switch Signal
E27 - Open Throttle Switch Signal
E47 - BCM-PCM Data Problem
F32 - BCM-ECM Data Problem
