Results 1 to 3 of 3
Thread: 1989 Deville code help
    showett is offline Cadillac Owners Member
    Automobile(s): 84 Fleetwood
    Jan 2008
    Elgin, IL
    34
    4
    Trying to help my girlfriends brother fix his car and got codes
    madmike69's Avatar
    madmike69 is offline Cadillac Owners Member
    Automobile(s): ´88 Fleetwood Brougham de Elegance, ´88 Sedan De Ville
    Jul 2007
    Hamburg, Germany
    43
    90
    Re: 1989 Deville code help
    Hi,
    sorry, i don´t understand your post.
    WHICH codes do you have ?
    or dou you want to know HOW to pull ´em ?
    Jan 2008
    Elgin, IL
    34
    4
    Sorry, the post was not complete. The problem is the car idles very high and sometimes dies out completely, also the fuel data center will constantly cycle through all the options and cannot be stopped. Could the bad computer cause the e26&e27 codes and the high idle, and the tps/isc not actually be bad?
    E26 - Shorted Throttle Switch Signal
    E27 - Open Throttle Switch Signal
    E47 - BCM-PCM Data Problem
    F32 - BCM-ECM Data Problem
    Thanks.
  • You may not post replies
