car doesn't switch to 3rd gear
Results 1 to 7 of 7
HT4100 4.1, 4.5, 4.9 Discussion, car doesn't switch to 3rd gear in Cadillac Engine Discussion; HI my '88 Fleetwood doesn't switch to 3rd gear. I had problems with rough engine as I posted in another ...
    Romy is offline Cadillac Owners Member
    Automobile(s): 1988 Fleetwood D'Elegance
    Jul 2007
    Switzerland
    42
    52
    HI
    my '88 Fleetwood doesn't switch to 3rd gear. I had problems with rough engine as I posted in another thread. But his problem is solved now. Engine runs smooth. Now all of a sudden it doesn't switch to 3rd gear. We adjusted the TPS after changing plugs and wires. Does this has somthing to do with this switching problem? Thanks for any help.
    romy
    madmike69's Avatar
    madmike69 is offline Cadillac Owners Member
    Automobile(s): ´88 Fleetwood Brougham de Elegance, ´88 Sedan De Ville
    Jul 2007
    Hamburg, Germany
    43
    90
    Re: car doesn't switch to 3rd gear
    Hi,
    - do you have any trouble codes?
    - did you check the wires, going into the trans, which control the gear shift solenoids (or "servos" in german)
    Jul 2007
    Switzerland
    42
    52
    no codes. But I will check the wires.
  5. #4
    Jul 2007
    Switzerland
    42
    52
    Well, checked the wires and cleaned the contacts in the brake switch. They were dirty. After that checked the voltage on the wires that go to transmission. Got 10 V and 0 V when brake pedal is pressed and not. It seems that the wires are ok and the transmission gets the 10V to switch BUT it doesn't! Still no codes...
    Will check the wires from trans to ECM tomorrow. Will also replace ECM to ckeck if ECM may be bad.
  6. #5
    madmike69's Avatar
    Jul 2007
    Hamburg, Germany
    43
    90
    Hi Romy,
    You should do that. I guess this will make claer, if you have an ECM Problem (still no codes...)
    which would be cheaper or if you have a "hardware" Problem with the trans...
    Actually i don´t know if there´s access to the shifting solenoids / servos without removing
    the complete transmission unit. Just got my service manual today...
  7. #6
    Jul 2007
    Switzerland
    42
    52
    I got a spare ECM. So I can check this without buying one. But I really hope that there won't be anything wrong with the transmission. I will come back later.
  8. #7
    Jul 2007
    Switzerland
    42
    52
    replaced ECM and engine works better than before. But it still doesn't switch. It happend once but then again not. Don't know if solenoid works right.
  9. Remove Advertisements
