Results 1 to 5 of 5
Thread: 88 Sedan Deville 4.5L intermittently starts, sometimes dies driving
    freshie976 is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Jul 2008
    4
    My 88 Sedan Deville will start up fine sometimes and run great, sometimes even for a day or two. Then, it will decide not to start. It turns over fine, but won't fire. If I let it sit for awhile, sometimes only 30-40 minutes, it starts up and runs fine till it decides to act up again. Here lately it's started dying while driving, then it will start again. Help!
    madmike69's Avatar
    madmike69 is offline Cadillac Owners Member
    Automobile(s): ´88 Fleetwood Brougham de Elegance, ´88 Sedan De Ville
    Jul 2007
    Hamburg, Germany
    43
    90
    Re: 88 Sedan Deville 4.5L intermittently starts, sometimes dies driving
    Hello,
    had the same problems:
    http://www.cadillacforums.com/forums...-problems.html
    Check your ground Cable at the negative Battery Pole. There´s an electric Connector which caused my Problems.
    As You wrote in your other Post, you have the Code pulled "ECM Memory Reset", i gues you have a "ground" Problem.
    good luck !
    Jul 2008
    4
    Thanks for the advice, I'll check it out. My fuel center and climate controls work perfectly though. The main problem I'm having is with intermittent starting, and stopping while driving along. Today I had to go somewhere, and it stopped on my halfway to my destination, only to restart immediately and not give me any more problems. After I pulled the codes yesterday, I cleared them. When I got home today, I checked the codes and got E53 again, which is distributor signal fault(interrupted). So, I still don't know. I'll check the negative wires though. Thanks.
  5. #4
    Lithorian's Avatar
    Lithorian is offline Cadillac Owners Enthusiast
    Automobile(s): 1995 Deville 4.9 Liter, 1988 Camaro Iroc-Z 5.0 Liter
    Dec 2007
    508
    pick up coil..
  6. #5
    Dave S Texas's Avatar
    Dave S Texas is offline Cadillac Owners Enthusiast
    Automobile(s): '87 Coupe DeVille 4.1L FWD(New engine '08) 1981 F100 '03FXDL
    May 2008
    Austin(area), Tx
    73
    879
    "I checked the codes and got E53 again, which is distributor signal fault(interrupted)"
    Among the codes: is E12, or E.E.12 showing?
  • You may not post replies
