gear indicator fault :(
Results 1 to 10 of 10
HT4100 4.1, 4.5, 4.9 Discussion, gear indicator fault :( in Cadillac Engine Discussion; anyone know what this means and if i can fix it myself?...
    Brizzal's Avatar
    Brizzal is offline Cadillac Owners Enthusiast
    Aug 2007
    West Palm Beach, FL
    28
    847
    Lithorian's Avatar
    Lithorian is offline Cadillac Owners Enthusiast
    Automobile(s): 1995 Deville 4.9 Liter, 1988 Camaro Iroc-Z 5.0 Liter
    Dec 2007
    508
    Re: gear indicator fault :(
    ITS USER GENERATED, LIKE WHEN YOU DONT QUITE put it all the way in gear and all the boxes light up, i did it on accident once, clear the code and keep on drivin :P
    Brizzal's Avatar
    Aug 2007
    West Palm Beach, FL
    28
    847
    its a I027 (PRND321 switch failure) code and cannot be cleared any ideas?
    Automobile(s): 1999 BMW 740 Il. 2005 Jag XK8, 1988 Mercedes Benz 300 SE
    Feb 2003
    california
    69
    6,689
    The neutral switch mounts on the transmission. If it is out of adjustment or loose, this code will set. Also if internally shorted, it will set a code as well. Hard to describe adjustment procedure, You need the factory service manual if you decide to do this yourself. Can you get the dealer service advisor to burn a copy of the diagnosis for you? from the manual.
    Lithorian's Avatar
    Dec 2007
    508
    1. Disconnect battery ground cable.
    2. Disconnect shift cable from transaxle.
    3. Disconnect electrical connector from switch.
    4. Remove two switch mounting bolts and then the switch.
    5. Align flats on switch with flats on transaxle shaft and push switch over shaft and fully seat on transaxle.
    6. Install and torque switch mounting bolts to 20 ft. lbs. If switch was rotated and pin is broken, switch will be automatically reset to neutral position as follows:
    1. Place transaxle shaft in neutral position.
    2. Install switch on transaxle as outlined previously and loosely install mounting bolts.
    3. Insert a 3/32 inch gauge pin into service adjustment hole of switch.
    4. Rotate switch until pin drops in detent.
    5. Torque mounting bolts to 20 ft. lbs.
    Feb 2003
    california
    69
    6,689
    excellent post LITHORIAN! Now we hope he does this then posts back with results?
    Brizzal's Avatar
    Aug 2007
    West Palm Beach, FL
    28
    847
    yea awesome post lithorian! thanks so i need to get a new switch? called the auto parts store and it was $80
    Feb 2003
    california
    69
    6,689
    NO, you need to perform the steps as written to diagnose whether or not you need a switch. As I said, it can be as simple as a loose or misadjusted switch. Or the connector on the switch not fully seated. Codes NEVER tell you what part to replace, they tell you what circuit to diagnose and if the diagnosis confirms a faulty component, then you replace it without guessing.
    madmike69's Avatar
    madmike69 is offline Cadillac Owners Member
    Automobile(s): ´88 Fleetwood Brougham de Elegance, ´88 Sedan De Ville
    Jul 2007
    Hamburg, Germany
    43
    90
    Hi,
    had the same problem with my former ´91 buick park avenue.
    The prnd switches bolts were just loose on top of the trans...
    Adjusted it like Lithorian wrote and the problem was gone.
    good luck
    Feb 2003
    california
    69
    6,689
    Nice to be $80.00 ahead as well!!
  13. Remove Advertisements
