ht 4100 crankshaft flange 9Harmonic balancer) removal tool?
Results 1 to 4 of 4
HT4100 4.1, 4.5, 4.9 Discussion, ht 4100 crankshaft flange 9Harmonic balancer) removal tool? in Cadillac Engine Discussion; Hi, I am working 0n a 1983 fleetwood with a ht4100 engine. I am now replacing the timing chain but ...
    ntodaro1 is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Jun 2008
    1
    Hi,
    I am working 0n a 1983 fleetwood with a ht4100 engine. I am now replacing the timing chain but can NOT get off the crankshaft flange for mounting the harmonic balancer. Is there a special puller needed. I try a pretty big 3 jaw puller but no luck. Ant help is greatly needed asap. Thank you in advance.
    cadillac_al is offline Cadillac Owners Connoisseur
    Automobile(s): 70 Deville 77 Fleet 78 Seville 92 Deville 03 Deville
    Feb 2007
    Maine
    55
    3,310
    Re: ht 4100 crankshaft flange 9Harmonic balancer) removal tool?
    Be careful with a 3 jaw puller!!! It's not hard to damage those things; especially Buicks. I haven't messed with a Caddy 4.x balancer but I suspect there may be some holes or slots with holes inside to thread a puller to. Time to invest in a manual. Good luck.
    84delegance's Avatar
    84delegance is offline Cadillac Owners Member
    Automobile(s): 84 Fleetwood brougham d'elegance
    Jan 2008
    23701
    25
    ive got a 84 fleetwood brougham and i just replaced the timing chain on mine and if i remember correctly i did use a harmonic ballancer pulley puller that i rented from autozone and it came off with a little force just dont ruin the threads on the inside of the crank shaft you will need it to reinstall. i did have a hard time finding the right threads for the crank to reinstall though.
    SubieHo is offline Cadillac Owners Member
    May 2008
    21
    Yes, a harmonic balancer puller is what you need. Here' how it looks:
  7. Remove Advertisements
