4.9l stumble
Results 1 to 15 of 15
HT4100 4.1, 4.5, 4.9 Discussion, 4.9l stumble in Cadillac Engine Discussion; I have 92 4.9l . My problem: Surging/Stumbling/Hesitation upon light acceleration. What I have done so far: replaced bad/old vacuum ...
    wanobi is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Apr 2008
    6
    4.9l stumble
    I have 92 4.9l .
    replaced bad/old vacuum lines
    cleaned TB blades and egr tubes
    got my hands on a data reader
    had a intermitting signal from the map. connector was not tight.
    information I have:
    when the engine starts its Surging/Stumbling/Hesitation routine I noticed that my left bank injector pulse time is flucuating. The right bank stays constant or smoothly increases as I accelerate.
    Questions:
    1. What controls the injector pulse times?
    2. Which is the left bank?
    3. What else could be causing the Surging/Stumbling/Hesitation
    TIA,
    Rod
    Feb 2003
    california
    69
    6,664
    Re: 4.9l stumble
    Left bank is the one closest to radiator.
    Feb 2003
    california
    69
    6,664
    Re: 4.9l stumble
    Try some SEAFORM brand injector cleaner. Sounds like dirty injectors. The ECM gets pulse width info from a few sources, but the TPS angle is the main one.
    HUF's Avatar
    HUF
    HUF is offline Cadillac Owners Connoisseur
    Automobile(s): 1995 FWB 100,*** miles CURRENT. 1991 Seville 175,000 SOLD
    Dec 2005
    MA
    58
    2,112
    Re: 4.9l stumble
    Four injectors on every side have a common connector (two connectors totally). I would make sure they are fine (disconnect/reconnect). The ECM (powertrain computer) has drivers for injectors. Those drivers might be bad. Also check the resistance of the injectors. You can do that right on the connectors I have mentioned. They should be around 17 ohm.
    Apr 2008
    6
    Re: 4.9l stumble
    thanks for the info. I am going to try the injector cleaner. but first I will ohm out the injectors..the connectors for each bank. do they connect to the ECM or do they plug into another connector before getting there. I guess I could just follow the wires?
    I will post back with my findings.
    Rod
    HUF's Avatar
    HUF
    Dec 2005
    MA
    58
    2,112
    Re: 4.9l stumble
    Quote Originally Posted by wanobi View Post
    Rod
    On the engine side a connector is wired to the individual injectors, which are represented by VERTICAL pairs of pins. You will figure out, I am sure.
    NickySantoro is offline Cadillac Owners Fanatic
    Automobile(s): 1993 Eldo 4.9 66K miles
    Nov 2005
    Nazi Jerky, libtard central
    368
    Re: 4.9l stumble
    Since each FI bank is fused separately, you might want to check for corrosion at the fuse block.
    Apr 2008
    6
    Re: 4.9l stumble
    Update: I ohm'd out the injectors and they all read 17.5 give or take an ohm. I kept wanting to lean towards the EGR system, so I bit the bullet and bought a new EGR solenoid. Performed the idle relearn procedure and it now is idling smoothly. Took it for my test drive and no hestitation or stumble. Now for real world driving to see if it is truly fixed.
    Rod
    HUF's Avatar
    HUF
    Dec 2005
    MA
    58
    2,112
    Re: 4.9l stumble
    Rod
    Glad the fix was an easy and cheap one! Check the resistance of your injectors every year. So far they are good.
    Apr 2008
    6
    Re: 4.9l stumble
    just got home from work. If it still has the hesitation/stumble its not doing it enough to make me think otherwise. Did have something new happen once I got home and put the car in park.
    Heard a clunk sound and the car kinda lurched, but it was in park. It did it twice before I turned the car off. I have a gloom and doom feeling coming on. Please tell me I'm wrong, unless it's the truth.
    TIA
    Rod
    HUF's Avatar
    HUF
    Dec 2005
    MA
    58
    2,112
    Re: 4.9l stumble
    TIA
    Rod
    Might be transmission sprag...
    Apr 2008
    6
    Re: 4.9l stumble
    what is transmission sprag??
    Lithorian's Avatar
    Lithorian is offline Cadillac Owners Enthusiast
    Automobile(s): 1995 Deville 4.9 Liter, 1988 Camaro Iroc-Z 5.0 Liter
    Dec 2007
    508
    Re: 4.9l stumble
    how much money you got? cuz its time for a rebuild.
  16. #14
    Nov 2005
    368
    Re: 4.9l stumble
    OP,
    Pull the distributor cap and check the wiring harness and connections at the ignition control module for looseness or corrosion. Is the problem more pronounced when the engine is hotter?
  17. #15
    Apr 2008
    6
    Re: 4.9l stumble
    ok, last update. changed plug, plug wires. distributor cap and rotor button. So far all seems well. Driven the car about 70 miles a day for a week and no major complaints. Car is idling about 100 rpms to high but I can live with that.
  18. Remove Advertisements
