86 Seville, 4.1, low idle in drive
Results 1 to 4 of 4
HT4100 4.1, 4.5, 4.9 Discussion, 86 Seville, 4.1, low idle in drive in Cadillac Engine Discussion; 86 seville, 4.1, 48,000 miles. After the car is warmed up I seem to have a low idle in drive ...
    ht4100's Avatar
    ht4100 is offline Cadillac Owners Fanatic
    Automobile(s): Triple Yellow 88 Biarritz, 92 Allante, 05 STS
    Nov 2005
    Lincoln, Nebraska
    103
    86 seville, 4.1, 48,000 miles. After the car is warmed up I seem to have a low idle in drive or reverse when car is not moving, ie stop lights. It idles between 525-600rpm. I have replaced the plugs, wires, cap, rotor, fuel filter, air filter, pcv with delco parts. The motor sounds fine, no noises or anything like that. I have also taken off the air cleaner assembly and cleaned the TB with cleaner. One thing I noticed was that the metal tube that connects from the exhaust manifold to under the air cleaner assembly is not fully attached at the exhaust manifold. The only trouble code is B336. The car always starts, never dies or stalls, just low idle. Any ideas? thanks
    carnut is online now Cadillac Owners Master
    Feb 2003
    california
    69
    6,662
    Re: 86 Seville, 4.1, low idle in drive
    Doesn't seem low to me. My 84 Eldo idles at 600 to 625 warm. My 91 Allante idles at 650 to 700 warm. The hot air stove to the air cleaner has no effect except regarding gas mileage. If that hose (metal hose)is off, the door in the air cleaner inlet wont open which restricts air intake thus lowering fuel economy. You can verify ISC (idle speed control) motor operation by watching it extend and retract as the A/C compressor cycles on and off. If it extends a 1/2 second before the compressor cycles on, then retracts just as the compressor goes off, its working as designed. Unless you are familiar with adjusting TPS and ISC and minimum idle, leave it alone. Its within 50 RPM of spec.
    awadecki is offline Cadillac Owners Enthusiast
    Automobile(s): 76 Eldo (54k), 76 Eldo (52k), 78 Eldo (9k), 85 Deville (43k)
    Jun 2005
    Michigan
    668
    Your idle speed is fine. Normal idle is 530-550 rpms in drive. The car has an idle speed controller that will bump up the idle if a load is placed on it. Otherwise, it putts along slowly in order to conserve gas.
    Jun 2005
    Michigan
    668
    Btw, both my 4.1 engines idle at 550 in drive when warm.
  7. Remove Advertisements
