4.5 questions
Results 1 to 7 of 7
HT4100 4.1, 4.5, 4.9 Discussion, 4.5 questions in Cadillac Engine Discussion; I just recently purchased my First Cadillac. Car is in Amazing Condition. It is a 1988 Eldorado. Car Starts right ...
    THudson is offline Cadillac Owners Member
    Automobile(s): Cadillac Eldorado
    Jun 2008
    St Catharines
    4
    4.5 questions
    I just recently purchased my First Cadillac. Car is in Amazing Condition. It is a 1988 Eldorado. Car Starts right away and runs well for a car that is 20 years old. It does sound a little rough does not appear to Idle down after starting and the heat coming off the car is intense. It has a chemical smell, but does not appear to have any leaks. I have had tranny drained, pan cleaned with magnet and new filter. Coolant flushed and replaced. Oil changed. All done at the dealer ship.
    I see that in another thread you mention to only use Ac Delco plugs I have not looked into that. Anything else that might cause Heat coming from underneath the car and the chemical smell. The power steering seems to hum as well. I think the car has been sitting for some time and there may be a number of things that need to be done the original voque tires are on the car as well. Your help in restoring this amazing car would be greatly appreciated
    Sincerely
    Trevor Hudson
    Jun 2008
    St Catharines
    4
    Re: 4.5 questions
    Ok I performed an ECM diagnosis
    and this is what it said
    NO ECM Codes
    B120 Current
    B121 History
    B127 History
    B552 History
    then It said
    ECM?
    What does ECM? mean
    Hope someone can help me Diagnose So I can get the car running in Concours Condition!
    Thanks
    Trevor
    HUF's Avatar
    HUF
    HUF is offline Cadillac Owners Connoisseur
    Automobile(s): 1995 FWB 100,*** miles CURRENT. 1991 Seville 175,000 SOLD
    Dec 2005
    MA
    58
    2,112
    Re: 4.5 questions
    Engine Control Module
    Check the codes here:
    http://www.cadillacforums.com/forums...x-engines.html
    Jun 2008
    St Catharines
    4
    Re: 4.5 questions
    Sorry I did print out the codes but the ECM actually Posted "ECM?" on the screen. What does "NOCODES" and "ECM?" mean
    Is the ECM faulty? or did the last time it was serviced cleared the codes?
    thanks
    Trevor
    illumina's Avatar
    illumina is offline Cadillac Owners Connoisseur
    Automobile(s): '98 Buick Regal LS - '91 Caddy Seville - '87 Caddy Seville!
    Feb 2004
    The Empire...
    4,425
    Re: 4.5 questions
    Quote Originally Posted by THudson View Post
    Sincerely
    Trevor Hudson
    A power steering hum is quite normal for these cars, especially a car that is 20 years old.
    As for the smell and stuff, it may be that the cross-under pipe may be the culprit for the heat and perhaps some old oil residue is just burning off of the pipe.
    Or your car is about to explode!
    Jun 2008
    St Catharines
    4
    Re: 4.5 questions
    Well I had the Ontario Drive clean done and it passed with Flying Colours....so no explosions, I am changing the plugs, wires and cap to Ac Delco! and new fuel filter and thermostat just to be on the safe side. As for the smell I think your right just had the exhaust replaced and had the transmission fluid changed so maybe some transfered onto the exhaust and has been burning off. Today their was no smell. I'll take it for now and continue to change things as I go.
    thanks
    Trevor Hudson
    hthorn is offline Cadillac Owners Member
    Feb 2008
    47
    Re: 4.5 questions
    IIRC, "ECM?" means it's asking you if you want to run diagnostics on the ECM. You can toggle through several more; I don't remember them all. Sounds like everything's cool with the ECM; all your codes are coming from the BCM. You got a real cream puff there. Happy motoring!
  10. Remove Advertisements
