Yeah, I drove it down the block to my friends house so we could shop vac the inside and we noticed it was slipping worse.
I popped the hood and checked the fluid. It was empty! I put some in and the car now shifts fine. I probably should have done that when I first got the car, but I'm still no where near done working on it and only drove it maybe two blocks since I've owned it. (Sat for years before I bought it)
I'm thinking I probably lost a lot of it when I changed out the radiator the day before because it was sitting disconnected for a few days so some might have dripped out from the cooler lines. Also, I did turn it over once w/ no radiator (bad idea, but it was for a quick test b/c we couldn't even get the car to start then). When I turned it on, it sprayed out about 1/2 the oil and I suppose transmission fluid the few seconds it was on out of the hoses.
Chalk this one up to my own stupidity.
Unrelated question, but I figure it's not worth making a new thread over. Today I turned the car on and it ran a bit rough so the SES light was on. (First time since I got it running). I turned the car off, put the car in the "on" position and went to check the codes by shorting the test terminal. When I did the the SES light came on and stayed on and the fuel economy part of the dash just read "0.0". I didn't see any codes blink. Was there a seperate button I had to press to show them? I know this car has some sort of complex diagnostic system built in... or did the codes not save once I turned it off? (I read in my chiltons book that there were two types of ways cadillac had the codes, where they are saved and where they erased after it's turned off... I figure that an '82 should save the codes... my '84 chevy does...)
Any ideas?
