Cruise Control Problem!!
Results 1 to 9 of 9
HT4100 4.1, 4.5, 4.9 Discussion, Cruise Control Problem!! in Cadillac Engine Discussion; When I try to use my Cruise Control I will get a message displayed "Cruise Engaged" then ill let of ...
    caddyman4.9 is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Jun 2008
    4
    When I try to use my Cruise Control I will get a message displayed "Cruise Engaged" then ill let of the gas but the vehicle doesnt keep its speed it slow down. its not working but i have no relating codes either. could somebody help me out. im moving to milwaukee soon and i would like to use it. thanks
    1995 cadillac deville HT4900
    Feb 2003
    california
    69
    6,640
    Re: Cruise Control Problem!!
    Have you opened the hood to verify its hooked up? Is the cruise control cable connected to the throttle arm? do the brake lights work?
    Jun 2008
    4
    yes the cable is hooked up it moves with the engine being reved and yes everything works except this
    Feb 2003
    california
    69
    6,640
    Years ago to diagnose a lack of cruise control, I put my foot UNDER the brake pedal and lifted up as I set the cruise. The system worked great unless I removed my foot, then it would quit. Found that the release switch mounted on the brake pedal pivot bracket was misadjusted. So try that above 35 MPH.
    Jun 2008
    4
    Hey "carnut" ummm when i use my e-brake and when i put the ignition in the on position it doesnt release i have to manually release the e-brake could this be the problem and if so how would i adjust the e-brake so it releases with the ignition.
    Dave S Texas's Avatar
    Dave S Texas is offline Cadillac Owners Enthusiast
    Automobile(s): '87 Coupe DeVille 4.1L FWD(New engine '08) 1981 F100 '03FXDL
    May 2008
    Austin(area), Tx
    73
    876
    I feel your pain! I've been dealing with a cruise problem for a very long time and haven't figured it out yet. Mine works perfectly the first time I use it, but after that it forgets how to work properly. It engages, lets off, engaging, letting off....kinda herky-jerky like. I cleaned all the electrical connections and that helped some, but it wasn't the cure I've been looking for. No codes displayed. I keep thinking it's heat related, because, if I remember correctly, it always works ok in cold weather.....
    pompste is offline Cadillac Owners Connoisseur
    Automobile(s): 1995 SEDAN DEVILLE-4.9 & 1978 SEDAN DEVILLE-425
    Jan 2007
    1,673
    Quote Originally Posted by caddyman4.9 View Post
    Had the same problem with my cruise and parking brake after a recent tune-up.If you also don`t get any air flow from the front dash air vents it`s a disconnected vaccuum hose under the hood.All 3 systems tie into this 1 vaccuum hose----if it`s disconnected or has a leak.
    My mechanic accidently disconnected it when changing plugs and wires on my 1995 Sedan Deville 4.9 liter.
    The hose is only 1/8" diameter and is located on the drivers side under the hood against the firewall.Check both ends.
    Feb 2003
    california
    69
    6,640
    The auto release is activated by a vacuum diaphram assembly mounted on the park brake assemby. Verify the hose to it is on and not kinked. Most times the diaphram itself fails not the hose to it, may you'll get lucky? Ck what POMPSTE says, sounds quite possible. The release is activated by moving the gear shift, not simply starting the car. A hose comes from a switch at the base of the steering column.
    PaulPool89 is offline Cadillac Owners Member
    Automobile(s): 1995 Deville
    Jul 2011
    27
    11
    I had this same problem (sorry for the bump) and I found the small vacuum lines that go from the cruise control and blower motor were dry rotted. I replaced them and it worked again!
  12. Remove Advertisements
