Water Pump Inlet Repair help
Results 1 to 15 of 15
HT4100 4.1, 4.5, 4.9 Discussion, Water Pump Inlet Repair help in Cadillac Engine Discussion; Hi everyone. So i have spent the past 4 hours reading all the threads related to this part. it is ...
    Hamspiced is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Jun 2008
    6
    Hi everyone.
    it is the water inlet or rear water pump cover or whatever else its listed. i have through mitchell the part listed as water pump inlet assembly.
    well there is a hole rusted in it. i need to know what this part is called, where i can get it (gmpartsdirect.com doesnt have it, nor does autozone, murrays, napa) only place i havent tried is dealer.
    next, how is it removed? diagrams would be lovely, as i have the water pump removed right now and have attempted to remove this but there is just so much stuff blocking it i dont know what to do.
    HUF's Avatar
    HUF
    HUF is offline Cadillac Owners Connoisseur
    Automobile(s): 1995 FWB 100,*** miles CURRENT. 1991 Seville 175,000 SOLD
    Dec 2005
    MA
    58
    2,109
    Re: Water Pump Inlet Repair help
    The model, year, engine would be lovely.
    Jun 2008
    6
    sure would wouldnt it???
    doh
    92 seville sts 4.9
    HUF's Avatar
    HUF
    Dec 2005
    MA
    58
    2,109
    can you see the part you are talking about in this diagram?
    Jun 2008
    6
    follow the right side of the diagram, the three pullys on the right side going down. the middle one is the waterpump.
    the part i need is on the other side of the water pump. im assuming View C.
    HUF's Avatar
    HUF
    Dec 2005
    MA
    58
    2,109
    Quote Originally Posted by Hamspiced View Post
    Okay, that's a "dealer only" part about $30. Go to parts department of the nearest Cadillac dealership. Show it on their display and order.
    HUF's Avatar
    HUF
    Dec 2005
    MA
    58
    2,109
    See the picture. there are two heater pipes (that's how they are called) connected with a hose. Looks like you need the right one? If so, I can find the part number.
    Jun 2008
    6
    no, those arent it.
    I just replaced it. Its called the Rear Waterpump Inlet Assembly.
    There was a pin hole in the metal tube that attaches to the green tube of that tubing that you just posted.
    HOWEVER!!!
    I may have to replace those tubes anyways cause this thing was quite rusted.
    10 hours this took, to replace the waterpump and rear assembly. I can see why the shops charge so much.
    but now i still have leaking, i just have to figure out from where. i think my clamps might not be tight enough, or i have a busted radiator. eh, oh well. spent 80 bucks on the car, figure dropping a couple hundred will make it worth it.
    HUF's Avatar
    HUF
    Dec 2005
    MA
    58
    2,109
    no, those arent it.
    HOWEVER!!!
    These pipes do rust. Check the radiator's side tanks. They are plastic and often crack.
    Jun 2008
    6
    Quote Originally Posted by HUF View Post
    side tanks?
    like the resovour?
    i just got a price quote for a new radiator just to check... 260$.... christ!
    HUF's Avatar
    HUF
    Dec 2005
    MA
    58
    2,109
    side tanks?
    like the resovour?
    They are called inlet and outlet radiator tanks. An aftermarket radiator is about $150. Check out rockauto.com and eBay.
    Jun 2008
    6
    so lets say theoretically on one of the bolts for the waterpump i snapped it off.
    the one where the threaded part is sticking out and a nut secures the waterpump onto the engine. how does one go about fixing that?
    Slacker is offline Cadillac Owners Fanatic
    Automobile(s): 1987 Cadillac Fleetwood Brougham
    Jun 2008
    125
    I picked up a used radiator from a local junkyard for my deville for around $60. The thing looks great too. I'd suggest stopping by one of those places if you want to save some cash. Mine came w/ a 30 day warranty on it too.
    As for the threading of the snapped bolt. Sometimes if you have enough sticking out, I found you can dremel a standard screw driver slit in it with a cut off wheel and unscrew the bolt. If it's in too tight for that, you'll have to drill it out and retap the hole.
  16. #14
    caddy916 is offline Cadillac Owners Member
    Automobile(s): None posted
    Mar 2016
    SE Arizona
    36
    where did you find the waterpump inlet assembly and how much was it?
    This thread has been dead for almost 8 years. We doubt you'll receive a reply. Please look for more recent threads on your questions. Please update your profile with your vehicle year, model, engine.
    There are many, many good parts sources used by CF members - one is www.rockauto.com - another is www.autoanything.com.
  17. #15
    drewsdeville is offline Cadillac Owners Master
    Automobile(s): 2011 Crown Vic LX, 2009 Chevy Malibu 2LT
    Oct 2004
    Oak Creek, WI
    5,609
    The inlet will be a dealer-only item...
  18. Remove Advertisements
