1989 Seville code E13 Oxygen sensor not ready
Results 1 to 8 of 8
HT4100 4.1, 4.5, 4.9 Discussion, 1989 Seville code E13 Oxygen sensor not ready in Cadillac Engine Discussion; Hello, I am getting the oxygen sensor not ready code on my Seville. Does anyone know what I should look ...
    rjg
    rjg is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Jun 2008
    36
    Hello,
    I am getting the oxygen sensor not ready code on my Seville. Does anyone know what I should look for? Is the O2 sensor bad or something else setting it off? The car seems to run fine. Thanks for any help!
    Dave S Texas's Avatar
    Dave S Texas is offline Cadillac Owners Enthusiast
    Automobile(s): '87 Coupe DeVille 4.1L FWD(New engine '08) 1981 F100 '03FXDL
    May 2008
    Austin(area), Tx
    73
    876
    Re: 1989 Seville code E13 Oxygen sensor not ready
    Besides the E13 code, is there either a E45 or E44 showing too (intermittant or history)?
    rjg
    Jun 2008
    36
    Neither the 45 or 44 is showing up. Thanks for the help.
    carnut is online now Cadillac Owners Master
    Feb 2003
    california
    69
    6,664
    It wont be ready if the engine temperature is not to normal ( 195 to 210 F) Verify that thru diagnostics. 80 to 90 degrees C is the same. Should get there is 5 min. running. Or if the sensor is unplugged!!! it would not be ready. Or, if the sensor is a 2 wire sensor, its possibly not being heated.
    May 2008
    Austin(area), Tx
    73
    876
    Check out the suggestions of Carnut. The sensor may well be faulty and in need of replacement. The manufacturer recommends they be replaced every 30,000 miles. If the O2 sensor is faulty it's costing you money at the gas-pump.
    rjg
    Jun 2008
    36
    Well I replaced the O2 sensor. It was bad. It wasn't working since it was broke off and was hanging by the wires! And I thought there was an exhaust leak coming from the rear manifold!
    Feb 2003
    california
    69
    6,664
    Next time, before you post, open the hood!!
    May 2008
    Austin(area), Tx
    73
    876
    Quote Originally Posted by carnut View Post
    That is always good plan....
  11. Remove Advertisements
