1987 - 1989 Fan Control Module
Results 1 to 11 of 11
HT4100 4.1, 4.5, 4.9 Discussion, 1987 - 1989 Fan Control Module in Cadillac Engine Discussion; Hello all, I need a fan control module for a 1989 Seville. So far I have only found a used ...
    rjg
    rjg is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Jun 2008
    36
    Hello all,
    I need a fan control module for a 1989 Seville. So far I have only found a used one locally for $85.00. I've tried some of the internet junk yards and nothing has turned up. Does anyone know where I may be able to find one? Thanks for the help!
    ehall's Avatar
    ehall is offline Cadillac Owners Connoisseur
    Automobile(s): 1985 Sedan DeVille
    Aug 2007
    Southern Maryland
    1,883
    Re: 1987 - 1989 Fan Control Module
    I don't know but I know they are out there. The one on my '85 went out last year and a local shop bought a replacement from somewhere. It was expensive as $@*! ... about $200 if I remember right.
    Dave S Texas's Avatar
    Dave S Texas is offline Cadillac Owners Enthusiast
    Automobile(s): '87 Coupe DeVille 4.1L FWD(New engine '08) 1981 F100 '03FXDL
    May 2008
    Austin(area), Tx
    73
    876
    I recently had this same problem. There are modules for sale, and the price you stated is about right, but add shipping to that. What leads you to believe the module is faulty?
    rjg
    Jun 2008
    36
    Quote Originally Posted by Dave S Texas View Post
    With the air running, both fans run and the message cooling fan fault comes on. Also the one fan stayed running when the car was shut off.
    Thanks for the replies!
    kdcing is offline Cadillac Owners Fanatic
    Automobile(s): 1993 Eldorado, 4.9L, 200k miles
    Dec 2006
    273
    AutoZone has them between $18 and $75, however, double check the diagnosis....I believe both cooling fans are to be on w/ the AC. 1 fan running w/ engine off may not be normal, however.
    Finally, when calling around for this part, be clear that the needed control unit is for the cooling fans....I believe the year of your car also has a control unit for the HVAC fan.
    ehall's Avatar
    Aug 2007
    Southern Maryland
    1,883
    The FSM for my 85 describes a test in the on-board diag that lets you manually power up and down the fans. That is how I confirmed the control module had failed.
    May 2008
    Austin(area), Tx
    73
    876
    ok, if one fan stays On when using the OBD system, that is a faulty module. I was going to suggest you check the module ground, since that is the common problem with intermmitent F41 codes.....hope you can find a good replacement unit.
    wilsonwilson is offline Cadillac Owners Member
    Automobile(s): 1987 Seville
    Oct 2006
    Tennessee
    20
    TalkingRe: 1987 - 1989 Fan Control Module
    Quote Originally Posted by rjg View Post
    Hello all,
    If you have a Pull-a-Part close...I got one 2 years ago for $5.00 bucks, Bose Radio for $10.00 etc...
    Man it's almost a pleasure to get my own parts from this place....ALWAYS clean, all vehicles off the ground so to work under...NO I don't own stock in the place
    ehall's Avatar
    Aug 2007
    Southern Maryland
    1,883
    BTW, rockauto sells the AC Delco, it's listed under cooling systems, I think they call it radiator fan module
    rjg
    Jun 2008
    36
    After following the shop manual's steps it was determined to be the fan control module. I found a used one online. The error message went away also. Thanks for the replies!
    Oct 2006
    Tennessee
    20
    It's called:
    Cadillac/GM COOLING FAN CONTROL MODULE - 1634863 [Delco OEM Part#] / 1641400
    [Interchange Part Number]
    For 1986-1991 Cadillac Seville
  14. Remove Advertisements
