clamp-down dist caps
Results 1 to 4 of 4
HT4100 4.1, 4.5, 4.9 Discussion, clamp-down dist caps in Cadillac Engine Discussion; Looking at some of the performance distributor caps like MSD and whatnot, and they are mostly "clamp-down" instead of "screw-down" ...
    ehall's Avatar
    ehall is offline Cadillac Owners Connoisseur
    Automobile(s): 1985 Sedan DeVille
    Aug 2007
    Southern Maryland
    1,883
    Looking at some of the performance distributor caps like MSD and whatnot, and they are mostly "clamp-down" instead of "screw-down" however looking under the hood the distributor uses screw holes, and there does not seem to be enough room for clamping.
    Those of you who have done the higher end distributors with the clamping feet, what did you do about this?
    awadecki is offline Cadillac Owners Enthusiast
    Automobile(s): 76 Eldo (54k), 76 Eldo (52k), 78 Eldo (9k), 85 Deville (43k)
    Jun 2005
    Michigan
    668
    Re: clamp-down dist caps
    Not quite sure ehall, but I don't think you'll find much of a power advantage with one of these caps. Although brass tips last longer, aluminum is actually a better conductor.
    illumina's Avatar
    illumina is offline Cadillac Owners Connoisseur
    Automobile(s): '98 Buick Regal LS - '91 Caddy Seville - '87 Caddy Seville!
    Feb 2004
    The Empire...
    4,425
    When I ran with a transparent cap (comes in clamp-down style), I just found a set of screws long enough and added some springs to help with clamping force thus modifying the cap a bit. It didn't look bad at all, but when I had to take the wires off to check some things, the brass terminals fell off!
    Feb 2003
    california
    69
    6,663
    Dont waste the money! Just replace with DELCO cap.
  7. Remove Advertisements
