| 4.1 Spark Plug Wires Problem Solved (Maybe) My 87 Eldorado had been running rough so I did a full tune up (plugs , wires, cleaned throttle body etc) over a year ago. It ran better for a while but started runnig bad again. Over the last year I had fixed several problems that made the car run better but still, over time, it would start running bad again. Several months ago I found that the spark plug wires were arcing, so I replaced them with a better quality set: AC Delco wires. The car ran much better, but then started to gradually run bad again. To my surprize the plug wires were arcing again.
So I replaced them with 8.8mm Accel wires. The car runs better than it has for a long time, and the gas mileage is greatly improved (from 12 mpg to 17 mpg city driving).
I am puzzled why the AC Delco wires broke down so soon. I thought they should be good quality, though a local mechanic said he thought Accel and Belden (NAPA) were a lot better. I asked him if there was something in the ignition system that would cause plug wires to break down so soon and he said no.
So hopefully these Accel wires will last.
Anyone else have a similar experience? |
