Go Back   Cadillac Owners Group > General Discussion > Cadillac Engine Technical Discussion > HT4100 4.1, 4.5, 4.9
HT4100 4.1, 4.5, 4.9 This forum is to discuss the newer aluminum block Cadillac engines.
Cadillac Forums: Plug Gap on 4.9L??? (also Bosch Injector Question)
Old 05-02-08, 11:09 PM
Cadillac(s): Cadillac
View cjhudson87's Photo Album
Casino Cash: $430
Hello,
I am still fighting my stumble issue. Can anybody tell me what plug gap should be on a 1991 4.9L Seville? Mine are at like .060"
Also, I saw a post about Bosch 19lb injectors from 5.0 Mustangs being a hot upgrade for the 4.9L motors. I happen to have a known good set lying around from my 1988 Mustang and was thinking about throwing them in too. Will these work on my 1991 Seville?
Thanks!
  #2 (permalink)
Old 05-03-08, 12:08 AM
HUF's Avatar
HUF HUF is offline
Cadillac(s): 1995 FWB 87,*** 1991 Seville 175,000 SOLD
View HUF's Photo Album
Casino Cash: $15182
Re: Plug Gap on 4.9L??? (also Bosch Injector Question)
The gup should be 0.060". As for injectors, I am waiting for some input to.
  #3 (permalink)
Old 05-03-08, 01:12 PM
Casino Cash: $430
0.060"?
I've never had a vehicle that was supposed to have that huge a plug gap.
  #4 (permalink)
Old 05-03-08, 03:24 PM
Cadillac Owners Enthusiast
Cadillac(s): 93 Sedan Deville 4.9L
View behind-bars's Photo Album
Casino Cash: $13981
It says the gap on the emissions sticker under the hood, .06 sounds right from memory. The plugs I got (delco rapid fire) were pregapped.
  #5 (permalink)
Old 05-03-08, 11:25 PM
Cadillac(s): 1995 Cadillac Sedan Deville- 4.9 Litre
View pompste's Photo Album
Casino Cash: $9136
Originally Posted by cjhudson87 View Post
0.060"?
The .060 gap is correct.I had my plugs changed 2 weeks ago--ac/delco platinum tipped on my 4.9 litre.They came pre-gapped but i checked them myself anyway---they were correct.
  #6 (permalink)
Old 05-04-08, 10:06 AM
Cadillac(s): 1993 Eldo 4.9 66K miles
View NickySantoro's Photo Album
Casino Cash: $4005
Tah Dah!
Manual says......... .060"
BTW, always check the gap. It will take two minutes, if that, to check all eight. Mostly they are OK out of the box. Over the years I've seen far too many that were not for whatever reason. Personally, I'm unwilling to run the risk of installing an incorrectly gapped plug on #4 or #6 and having to battle those two twice.
  #7 (permalink)
Old 05-04-08, 12:40 PM
View ChadTanner's Photo Album
Casino Cash: $1310
I done alot of research and testing on these injectors.The 4.9 and the stock mustang injector [when flow tested] flowed about the same, at 40psi they both flowed in the 20ish range.Thats far more than this engine could ever use.I had a local diesel shop do the flow testing,The owner also built and raced 5.0 mustangs.He showed me the difference in the spray patterens between the two injectors.The caddy injector has a much better spray patteren than the mustang.He went as far to say"the caddy injector would be an upgrade for a stock 5.0"
  #8 (permalink)
Old 05-09-08, 05:17 PM
View 1badcad's Photo Album
Casino Cash: $5345
I just put BOSCH injectors in my 4.9 today,WOW what a difference.No more rough idle and hesitation on acceleration."CHANGE THEM AND NEVER LOOK BACK"
  #9 (permalink)
Old 05-09-08, 08:12 PM
HUF's Avatar
HUF HUF is offline
Casino Cash: $15182
Great! Is it possible to replace injectors without removing PS pump? Where did you get the injectirs? New or reman.?
  #10 (permalink)
Old 05-11-08, 11:47 AM
View 4.9fiero's Photo Album
Casino Cash: $2600
I got mine from Jegs www.jegs.com cheaper than dealer replacements. As for rebuilt, don't bother, these can't be taken apart and "rebuilt", they can only be cleaned. http://www.cruzinperformance.com/ will clean and flow check them for .$16.00 per injector + actual return shipping., I've used them for 3 sets and when I sent him my 4.9's he emailed me back with the news that one was plugged completely, the rest were so far out of spec that he wouldn't recommend continuing. Pointed me in the direction of Bosch and charged me $12 for his trouble. They don't sell injectors so he had nothing to gain, just an honest business.
  #11 (permalink)
Old 05-11-08, 08:40 PM
HUF's Avatar
HUF HUF is offline
Casino Cash: $15182
4.9fiero,
Thank you for the info. I should take care of my injectors ASAP too!
Tags: , , , , , ,
49l, bosch, gap, injector, plug, question
