where are the major grounding straps?
Results 1 to 5 of 5
HT4100 4.1, 4.5, 4.9 Discussion, where are the major grounding straps? in Cadillac Engine Discussion; I looked in the FSM, Haynes and Chilton books and none of them provide locations for the main grounding straps. ...
    ehall's Avatar
    ehall is offline Cadillac Owners Connoisseur
    Automobile(s): 1985 Sedan DeVille
    Aug 2007
    Southern Maryland
    1,883
    Anybody know?
    '85 Sedan DeVille w/ 4.1
    awadecki is offline Cadillac Owners Enthusiast
    Automobile(s): 76 Eldo (54k), 76 Eldo (52k), 78 Eldo (9k), 85 Deville (43k)
    Jun 2005
    Michigan
    668
    Re: where are the major grounding straps?
    The primary one is on the engine block, down by the starter.
    Feb 2003
    california
    69
    6,664
    All the rest connect to a common stud on the alternator bracket.
    ehall's Avatar
    Aug 2007
    Southern Maryland
    1,883
    Thanks. I cleaned and packed the negative battery ground on the left fender and also got the alternator ground stud, and could not find the strap on the block.
    Feb 2003
    california
    69
    6,664
    That ground strap on your engine goes from the front of your block to the alt. stud. Look carefully at the water pump area for the woven silver ground strap and its bolt.
  8. Remove Advertisements
