4.9 has irratic idle can you help
Results 1 to 6 of 6
HT4100 4.1, 4.5, 4.9 Discussion, 4.9 has irratic idle can you help in Cadillac Engine Discussion; I have a 1992 fleetwood the engine was replace with a used engine. When i start it cold it idles ...
    Wolfpath2004's Avatar
    Wolfpath2004 is offline Cadillac Owners Fanatic
    Automobile(s): 2005 CTS-V (Silver)
    Sep 2004
    Oak Grove, KY
    43
    126
    Question4.9 has irratic idle can you help
    I have a 1992 fleetwood the engine was replace with a used engine. When i start it cold it idles just fine. once the engine warms up the engine idle goes up and down. the idle speed controler goes in and out sometimes to keep the engine running..what is the problem?
    ehall's Avatar
    ehall is offline Cadillac Owners Connoisseur
    Automobile(s): 1985 Sedan DeVille
    Aug 2007
    Southern Maryland
    1,883
    Re: 4.9 has irratic idle can you help
    You need to get the ISC calibrated. Smaller shops don't always know to do it.
    Sep 2004
    Oak Grove, KY
    43
    126
    Re: 4.9 has erratic idle can you help
    the isc only goes in and out when the idle drops almost to the point of stalling
    awadecki is offline Cadillac Owners Enthusiast
    Automobile(s): 76 Eldo (54k), 76 Eldo (52k), 78 Eldo (9k), 85 Deville (43k)
    Jun 2005
    Michigan
    668
    hard to pinpoint your problem without more info. could be the oxygen sensor (only read by the computer when warm), could be a failing closed throttle switch in the isc, could be a bad ground. check the engine block grounds first. make sure your 02 sensor toggles between rich and lean.
    Sep 2004
    Oak Grove, KY
    43
    126
    Well my battery has a bad connection at the posts...im going to clean them up and secure them ...I'll get back with you on the results
    NickySantoro is offline Cadillac Owners Fanatic
    Automobile(s): 1993 Eldo 4.9 66K miles
    Nov 2005
    Nazi Jerky, libtard central
    368
    Quote Originally Posted by Wolfpath2004 View Post
    ...... once the engine warms up the engine idle goes up and down. the idle speed controler goes in and out sometimes to keep the engine running..what is the problem?
    I'd look for a vacuum leak very carefully.
  9. Remove Advertisements
