engine pinging off the line?
Results 1 to 2 of 2
HT4100 4.1, 4.5, 4.9 Discussion, engine pinging off the line? in Cadillac Engine Discussion; -------------------------------------------------------------------------------- I have a 95 sedan deville with 119K miles. I bought from a retired vet. Car is impecable!!! I ...
    SRTATEU's Avatar
    SRTATEU is offline Cadillac Owners Member
    Automobile(s): 95 Sedan Deville
    Oct 2007
    Western Burbs
    46
    41
    I have a 95 sedan deville with 119K miles. I bought from a retired vet. Car is impecable!!! I did my normal scheduled changes for my records oil, oil filter, pcv, air filter, fuel filter, seafoamed the motor. beforeing doing all this I heard the motoring pining off the start? I added premium gas and still heard the pinging? I added techtron additive to clean the injectors to a full tank of gas and still have the pinging?
    has anyone encountered this issue? if so what was the remedy? if any.
    any and all comments appreciated..
    Joel
    HUF's Avatar
    HUF
    HUF is offline Cadillac Owners Connoisseur
    Automobile(s): 1995 FWB 100,*** miles CURRENT. 1991 Seville 175,000 SOLD
    Dec 2005
    MA
    58
    2,117
    Re: engine pinging off the line?
    It is most likely spark knock caused with faulty EGR system. First make sure two EGR tubes inside of the throttle body (under the blades) are clean, if they are not, use a piece of a coat hanger to rod the carbon out. Make sure all the vacuum tubes coming out of throttle body are intact.
