radiator 1983 Eldorado refurb?
Results 1 to 11 of 11
HT4100 4.1, 4.5, 4.9 Discussion, radiator 1983 Eldorado refurb? in Cadillac Engine Discussion; My lower hose gave out this weekend, on my way to a first date and had to have the car ...
    nycnftm is offline Cadillac Owners Fanatic
    Automobile(s): 1983 Eldorado
    Jan 2008
    101
    My lower hose gave out this weekend, on my way to a first date and had to have the car towed home. Now that the radiator is empty and I am replacing the upper and lower hoses I wanted to ask you guys about refurbishing the radiator. The inside looks like crap. I will get a pic to attach tomorrow. An after-market replacement is about $200, but can I bring it to a radiator shop and have them go over it for less? Is this a good idea? Found this place which is about a 30 mile drive that I will contact on Monday radiator repair shop
    Suggestions?
    Andrew
    Feb 2003
    california
    69
    6,607
    Re: radiator 1983 Eldorado refurb?
    If it were mine, I'd replace both hoses fill the radiator with fresh water only and make sure no further engine damage. If, after a week all's well, then replace the radiator. If the car were newer I'd tell you to have it rodded out, but it being this old it will probably come apart in the cleaning process. New radiator requires the addition of the sealant listed on the white decal on the plate in front of the radiator.
    Edahall's Avatar
    Edahall is offline Cadillac Owners Enthusiast
    Automobile(s): 93 & 88 Allante, 88 Eldorado
    Jan 2004
    778
    Have you checked the price at www.rockauto.com?
    When mine went out, I was able to buy a radiator from them for cheaper than having mine rebuilt.
  5. #4
    behind-bars is offline Cadillac Owners Connoisseur
    Automobile(s): 93 Sedan Deville 4.9L
    Sep 2005
    Texas
    1,005
    I bought a new radiator from rockauto for my 93 for about 130. Local shop wanted 100 to repair my cracked side tank.
    I figured if I was going to pull the radiator I wanted to put a new one back in just incase the repair of the old didnt work so i didnt have to do it twice
  6. #5
    Jan 2008
    101
    Well think we discovered why I was overheating. I brought the original radiator to a radiator shop where they were going to rod/boil/clean it out only to tell me its FUBAR. Instead of buying a new one for $275 I bought a junkyard one with a warranty for $35 and brought it to be cleaned and pressured tested. So should I no longer use Bars Leaks or does it help the engine too? Hopefully I'll be driving again by Friday!!!
  7. #6
    Sep 2005
    Texas
    1,005
    I would add bars leak anyway, If used right it really cant hurt anything. Just use the recommended amount and you will be good.
  8. #7
    Feb 2003
    california
    69
    6,607
    there is a decal on the radiator crossbrace that demands the use of coolant supplement or sealer. The service manual says MUST be used every 2 years when coolant is drained and changed. This engine would corrode the intake gaskets and dump coolant on the camshaft if coolant is not replaced at a minimum of 2 years. Bars leak Gold is the same as GM supplement.
  9. #8
    Jan 2008
    101
    What s/b an easy thing is driving me nuts. I'm trying to get the metal lines in front of the radiator between it and the condenser screwed back in. Taking them out I scratched myself up pretty good, but now cannot get the top one on at all. Can you unscrew them at the connectors and put them on before dropping the radiator down? That would be so much easier.
    Andrew I tried and they won't budge, I think if I twist too hard they will break and I'll really be f'ed. I might try putting wd40 on it and hope to get it apart there. Any suggestions?
  10. #9
    Sep 2005
    Texas
    1,005
    It is a refurb radiator correct? Was it origionally out of a caddy?
    I had to get little adapters for my new one to hook the lines back up.
  11. #10
    Jan 2008
    101
    Yes it's the same thing out of an 85. Where did you find the adapters? The bottom one went in sorta fine the top one is the problem.
  12. #11
    Sep 2005
    Texas
    1,005
    Quote Originally Posted by nycnftm View Post
    If it is out of the same model i wouldnt worry about adapters. My radiator was a aftermarket one that came with the needed adapters. I am not sure what the problem with yours is. If the bottom one didnt go on that tight it will probably leak. Mine is a 4.9 so I am not sure what differences their is in the radiator.
    Sorry I couldnt help more
  13. Remove Advertisements
