| Re: The Surge - in my 4.9, not Iraq... Folks,
I am continuing to experience what seems to be some TPS/ISC problem. Since my last post, I had a mechanic look at the TPS and he claimed all is well. Here are my current symptoms:
1. motor is running a little bit rough -- jittery. This comes and goes a bit but I can feel it's just not quite as smooth as it should be when idling -- and accelleration is not as smooth, either.
2. Car will regularly slowly continue to accellerate after I've given it some gas in the 20-30 MPH range but I have released the pedal. This dies off after maybe 15 seconds.
Current codes set are E055, TPS misadjusted, and E098, idle shifting problem (fairly minor code). Obviously one possible conclusion is that the mechanic was wrong. He also made some comment downplaying an ISC problem, saying it somehow wouldn't come into play in the scenerio I'm describing?
Also is this something a good service station mechanic ought to be able to solve, or is it better to take it to the dealer (which I hate)?
Thanks for any insights! |
