4.9 switched to 87 oct., hard starts, re-time? - Page 2
Page 2 of 2 FirstFirst 1 2
Results 16 to 24 of 24
HT4100 4.1, 4.5, 4.9 Discussion, 4.9 switched to 87 oct., hard starts, re-time? in Cadillac Engine Discussion; Mine looks almost just like that except I have a gray interior. I believe the air suspension in the back ...
  1. #16
    LikeaDream is offline Cadillac Owners Member
    Automobile(s): 1992 Eldorado ETC
    Oct 2007
    47
    Re: 4.9 switched to 87 oct., hard starts, re-time?
    Mine looks almost just like that except I have a gray interior. I believe the air suspension in the back works because when I turn the key to on usually after a few seconds the compressors make a noise but I don't feel much in the way of movement. I used to, however.
    That reminds me to ask... I've noticed in about the last week when I turn the key to "on" but don't crank the engine I get a little electric motor noise that's enough to lightly vibrate the shift column handle (floor mounted shifter) and it is constant and will not go away unless I'm actually running the car. Anybody know what that is? It seems to be directly under and maybe slightly forward of the shifter.
  2. #17
    92EldoTC's Avatar
    92EldoTC is offline Cadillac Owners Enthusiast
    Automobile(s): Ex:'92 ETC 4.9 Current:'91 Sedan Deville 4.9
    May 2006
    Vegas, NV
    38
    691
    never heard of that one.
    you have floor or steering wheel shifter?
  3. #18
    pompste is offline Cadillac Owners Connoisseur
    Automobile(s): 1995 SEDAN DEVILLE-4.9 & 1978 SEDAN DEVILLE-425
    Jan 2007
    1,673
    I always run premium in my 4.9 liter----let`s face it,the engine was designed to burn premium fuel so i give it the right stuff.
    Back in the early to mid 1990`s,when the 4.9`s were produced----gas prices were reasonable------not absurd as they are now.
    For a couple of tankfills last year i tried 87 & 89 octane -----it knocked under load on 87 octane,and knocked less on 89 octane-----so ever since,91-93 octane only.It`s 20 cents a gallon difference between regular and premium---reasonable.
  5. #19
    Murphyg's Avatar
    Murphyg is offline Cadillac Owners Connoisseur
    Automobile(s): 2001 STS
    Oct 2003
    Ontario
    1,575
    Hey............92 Eldo.......Hey.........LikeaDream...
    Get a room eh or at least your own thread
    Quote Originally Posted by LikeaDream View Post
    Quote Originally Posted by 92EldoTC View Post
    Does your automatic level system work?
    The compressor on mine used to run all the time and you could actually hear it running.
    The dent on mine came from somebody backing into it and it messed up the air compressor for the rear suspension so the car was a little low in the back but it was cool because it looked like it had been lowered.
    The rear driver side wheel was a little bent also, the top of the wheel was in more than the bottom so it looked like the car was carrying too much weight on that side in the rear. That tire though didnt wear uneven and didnt affect the way the car drove.
    Here are some pics, check it out!
    http://www.cadillacforums.com/forums...some-pics.html
  6. #20
    Murphyg's Avatar
    Oct 2003
    Ontario
    1,575
    Quote Originally Posted by pompste View Post
    Thanx pomp for tryin to get it back on track
  7. #21
    RightTurn's Avatar
    RightTurn is offline Cadillac Owners 10000+ Posts
    Sep 2006
    Keep Right™
    41,011
    Quote Originally Posted by Murphyg View Post
    Murph--please clean your glasses. This IS LikeaDream's thread.
  8. #22
    Jan 2007
    1,673
    You`re welcome----it happens sometimes that a thread will evolve/get off track from the original,but sometimes it`s a good thing.
  9. #23
    Murphyg's Avatar
    Oct 2003
    Ontario
    1,575
    Quote Originally Posted by RightTurn View Post
    Howd you know I needed glasses ???
    Whoooooo........
    Guess I only went back 2 instead of 3.
    Sorry guys. Thanx for lettin me know.......
    guess could almost call this a bump now.
    BTW.....If it is figured out....then gotta be added here. Hopefully it will help others whilst searching....
    Sory gain
  10. #24
    EldoRedo's Avatar
    EldoRedo is offline Cadillac Owners Fanatic
    Automobile(s): 1991 ETC (Crimson)
    Jul 2006
    Bethesda, Md.
    232
    Count me among the 4.9 owners who have advanced the timing -- I'm at 13 degrees. It does take advantage of the 93 octane's energy. I have only had knocking a very few times on the hottest summer days accellerating on an upgrade. In return I get more HP and better MPG.
  11. Remove Advertisements
