Results 1 to 12 of 12
Thread: 93 Seville 4.9-Crank position sensor location?
    MrSeville4.9 is offline Cadillac Owners Fanatic
    Automobile(s): 1993 Cadillac Seville 4.9, 2004 Cadillac Escalade ESV 6.0
    Apr 2008
    Chicago, IL
    107
    I have 236000 miles and she's still running. I do most of my repairs myself. Recently, the car has been stalling, rough start up, and then just dying out. When it dies out, it comes back on in about 5 minutes, like it never cut off. I've changed my wires, cap, rotor, and control module. A friend told me to try the crank position sensor. So where is it? How many is there? Help, Anyone!
    NickySantoro is offline Cadillac Owners Fanatic
    Automobile(s): 1993 Eldo 4.9 66K miles
    Nov 2005
    Nazi Jerky, libtard central
    368
    Re: 93 Seville 4.9-Crank position sensor location?
    it's inside the distributor and requires removal of same to replace. Have you pulled the codes, if any? Have you checked out the coil?
    HUF's Avatar
    HUF is online now Cadillac Owners Connoisseur
    Automobile(s): 1995 FWB 118,*** miles
    Dec 2005
    MA
    58
    2,125
    The sensor is also known as Hall effect sensor.
  5. #4
    kdcing is offline Cadillac Owners Fanatic
    Automobile(s): 1993 Eldorado, 4.9L, 200k miles
    Dec 2006
    273
    During the stalling, rough starts and engine dying, confirm that fuel pressure is 40-50psi.
  6. #5
    brougham is offline Cadillac Owners Master
    Automobile(s): 1991 Cadillac Brougham D'Elegance 5.7 Litre, 1994 DeVille
    Jun 2003
    Canada
    6,474
    Its the cam sensor thats in the distributor not the crank sensor. But it can do the same sort of thing. Check the codes because they will say if its bad or not.
  7. #6
    Nov 2005
    368
    Quote Originally Posted by brougham View Post
    Actually they are both in the distributor on the 4X engines. The crank position sensor is more often called the pick-up coil with the cam position sensor also called the Hall effect switch as previously noted.
  8. #7
    Apr 2008
    Chicago, IL
    107
    Talking Re: 93 Seville 4.9-Crank position sensor location?
    Thanks everyone for the help. So i change the coil on top of the distributor and I thought i had cured the problem. It ran good without cutting off for about 3 or 4 days. Then it cut off, but started back up after turning it a few times. I've replaced everything in the ignition system accept the hall effect switch. Is there a way to tell if the switch is bad? How do you change it out?
  9. #8
    cadillac_al is offline Cadillac Owners Connoisseur
    Automobile(s): 70 Deville 77 Fleet 78 Seville 92 Deville 03 Deville
    Feb 2007
    Maine
    55
    3,310
    any codes?
  10. #9
    Apr 2008
    Chicago, IL
    107
    Here are my codes: PO52 History, IO34 History, IO39 History, IO52 History
    Sometime the PO52 and IO34 is Current.... NO ACP, NO SIR, PCM?
  11. #10
    Apr 2008
    Chicago, IL
    107
    Here are all of my codes that i got
    PO30, PO52, PO67, PO98, IO39
    Can some interpret these for me, ive been finding different meanings for these codes.
  12. #11
    Eddie91 is offline Cadillac Owners Member
    Automobile(s): 1991 Seville
    Apr 2012
    Bozeman,MT. Powell,WY
    11
    http://myweb.accessus.net/~090/dtcobd1.html#rss
    you can find the def of all the codes there
  13. #12
    Jun 2003
    Canada
    6,474
    I would have hoped the problem was fixed already in the last 4 years
  • You may not post replies
