4.1 dampener pulley bolt
Results 1 to 11 of 11
HT4100 4.1, 4.5, 4.9 Discussion, 4.1 dampener pulley bolt in Cadillac Engine Discussion; Help! I need a dampener pulley retainer bolt for my 1985 4.1 Deville! I have contacted a couple of GM ...
    rootercycles is offline Cadillac Owners Member
    Automobile(s): 1985 Deville with 4.1
    Feb 2008
    50
    Help! I need a dampener pulley retainer bolt for my 1985 4.1 Deville! I have contacted a couple of GM dealers to be told that has been obsoleted. I have looked all over the internet without luck and no used auto yards is going to mess with this for less than $50. Where else can I look? It is a 16mmX1.25 pitch and 30mm long.
    ehall's Avatar
    ehall is offline Cadillac Owners Connoisseur
    Automobile(s): 1985 Sedan DeVille
    Aug 2007
    Southern Maryland
    1,883
    Re: 4.1 dampener pulley bolt
    Do you have a Fastenal in your area? They will special order bolts and they are usually a few pennies
    Feb 2008
    50
    yeah, I ordered what I needed today. The high strength bolt and washer will be here wednesday.
    ehall's Avatar
    Aug 2007
    Southern Maryland
    1,883
    did you break $1?
    Feb 2008
    50
    $8 or something including shipping...
    Feb 2003
    california
    69
    6,680
    That engine if original had no retaining bolt! There was a factory installed piece of cork ( like one in a wine bottle) inserted in that hole. A bolt installed is a good idea, but was not there originally!!
    Feb 2008
    50
    no bolt? Really? There isn't anything that seems to hold it in there other than centrifical force and the belt. Doesn't sound right...
    Feb 2003
    california
    69
    6,680
    Its pressed on from the factory. It should not simply slip on like some other engines. If it comes off easily then the bolt is necc.
    Feb 2008
    50
    I did have to get it off with a puller, but I am surprised it is just a "pressed fitting". I'm going to go ahead and put the bolt I have on to make sure. Got enough problems with this thing without the dampener falling off!
    Feb 2003
    california
    69
    6,680
    I just looked at my 84 Eldo with 80,000 miles. It has the cork in the crank pulley! The threads in the crankshaft are there to enable a puller to remove then reinstall the dampner.
    dhuberasu's Avatar
    dhuberasu is offline Cadillac Owners Member
    Automobile(s): Cadillac 1985 fleetwood brougham
    Feb 2008
    bartlett, tn outside memphis
    31
    I have a 1985 Fleetwood Brougham with HT4100 and would also like a dampener bolt....was the 16MM x 30MM with 1.25 pitch end up being the right one? I cannot find combination on fastenal's website....do you have part numbers?
    thanks
    david
  14. Remove Advertisements
