Two Problems Not Starting and Stalling - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 19 of 19
HT4100 4.1, 4.5, 4.9 Discussion, Two Problems Not Starting and Stalling in Cadillac Engine Discussion; Well one piece at a time as i can afford it SO far NEW ICM, and rotor. Still stalling... Next ...
  1. #16
    gsabato is offline Cadillac Owners Member
    Oct 2005
    33
    Re: Two Problems Not Starting and Stalling
    Well one piece at a time as i can afford it SO far NEW ICM, and rotor. Still stalling... Next week new cap wires and plugs... I hope.
  2. #17
    kdcing is offline Cadillac Owners Fanatic
    Automobile(s): 1993 Eldorado, 4.9L, 200k miles
    Dec 2006
    273
    Quote Originally Posted by gsabato View Post
    All the terminals are black, chipped etc
    For a short term fix, you can try cleaning the cap's terminals w/ emory cloth or emery board (worst case, use sandpaper)....but it does sound like the cap really needs to be replaced, as you mentioned.
  3. #18
    Oct 2005
    33
    Heres the thing. Since I put in the rotor and the ICM the computer throws code e23 and runs worse than ever... I did find a busted vacuum hose and fixed that. Idle smoothed out a bit. I did clean the cap that helped some too... But whats the e23 code EST Signal? Timing? but why now with a new ICM?
  5. #19
    hthorn is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Feb 2008
    47
    Hello, n00b hthorn here...first post, FWIW...I once had a DeVille with an otherwise OK and < 130,000-mi 4.5. It would sometimes fail to start, and it gave the Distributor Signal Interrupt code. Replacing the battery (shorted cell) solved this. In your case, it sounds as though you have a combination of problems, one of which could be a vacuum leak. You can (carefully) use a can of ether or brakleen to troubleshoot for it (engine on of course), or you can simply replace all the vacuum hoses, and you could be on the right track with the PCV valve. Sorry I don't have the Haynes manual handy so I can't look up the e23 code...I have heard about defective power steering control switches causing stalling problems. If this switch fails, the idle is not increased enough to compensate for the additional load imposed by turning the wheel at idle; the engine fights to stay on a bit, then loses its struggle and dies...
  6. Remove Advertisements
