Coupe Deville 4.5 Rough Running - Page 2
Page 2 of 2 FirstFirst 1 2
Results 16 to 26 of 26
HT4100 4.1, 4.5, 4.9 Discussion, Coupe Deville 4.5 Rough Running in Cadillac Engine Discussion; I went thru all the original papers. The car has a major tune up back in 06. Since that time ...
  1. #16
    88_Deville_Executive is offline Cadillac Owners Member
    Automobile(s): 1988 Cadillac Deville Executive
    Sep 2007
    Fairview, OR
    28
    Re: Coupe Deville 4.5 Rough Running
    I went thru all the original papers. The car has a major tune up back in 06. Since that time the car went from 106K miles to now which is 115K miles. I think they are all in fairly decent cond?.
  2. #17
    Edahall's Avatar
    Edahall is offline Cadillac Owners Enthusiast
    Automobile(s): 93 & 88 Allante, 88 Eldorado
    Jan 2004
    778
    Are the plugs & wires AC Delco??? A lot of people have reported problems with other brands. Yes, do replace the coil. You might try misting the wires at night and looking very closely for any sparking that might be occuring.
  3. #18
    Sep 2007
    Fairview, OR
    28
    When you say misting, you mean taking a bottle of water and basically misting the wires to see anything?
  5. #19
    cadillac_al is offline Cadillac Owners Connoisseur
    Automobile(s): 70 Deville 77 Fleet 78 Seville 92 Deville 03 Deville
    Feb 2007
    Maine
    55
    3,310
    It's got a fairly recent tune up, and hesitates or weak on power and smells like sulfer.........hmmm............I wonder if that catalytic converter is original? It's starting to sound like the cat is clogging. If it's the cat, it may gradually get worse but you could keep driving it until it starts glowing or something. A clogged cat will alter your vacuum but I can't remember if it makes it way high or way low. You could take out a couple of the easy spark plugs to see what they look like. Keep us posted and good luck.
  6. #20
    Edahall's Avatar
    Jan 2004
    778
    Quote Originally Posted by 88_Deville_Executive View Post
    Exactly
  7. #21
    Sep 2007
    Fairview, OR
    28
    I am going to try and make it into a muffler shop tonight. They will do a test on it. I think its original - looks like it.. but of course that does not say much. It it requires replacement. The person quoted me 189 for the complete job (labor and all) so we shall see.
    Thanks all. Will keep you updated.
  8. #22
    awadecki is offline Cadillac Owners Enthusiast
    Automobile(s): 76 Eldo (54k), 76 Eldo (52k), 78 Eldo (9k), 85 Deville (43k)
    Jun 2005
    Michigan
    668
    If they say it's not clogged, I'd really check that coil if your plugs/wires are new. It sounds like your car is running rich. If the temp sensor isn't reading too cold, and the MAP is reading vacuum correctly, there's really no reason for it to run rich.
  9. #23
    Sep 2007
    Fairview, OR
    28
    So folks, I drove my car out there tonight to get the estimate done. He put it up in the air... He did not conn. anything to it, but claims based on how it started and the condition of the cat. it WAS bad and was causing the backlow, etc.
    I thought they might have done a slightly more thorough inspection but I don't do exhaust so I could tell ya less.
    He quoted me a price of 290.00
    Does this sound right? I might call another place tomorrow for a 2nd quote.
  10. #24
    Jun 2005
    Michigan
    668
    Well, the cat itself is probably $150 in parts alone. With the rest of the exhaust, that's probably $200 + 1 hr to do it. Sounds reasonable to me.
  11. #25
    Edahall's Avatar
    Jan 2004
    778
    I doubt that your CAT is causing your engine to miss. But before you spend all that money, do a back pressure test first. Or if the mufflers guys are so sure that your CAT is the problem, draft an agreement and have them sign it that you won't owe them anything except the cost of parts if installing a new CAT doesn't fix the problem.
  12. #26
    Sep 2007
    Fairview, OR
    28
    I called another muffler place and they gave me a quote of 189 for the complete (+ Labor) replacement of the cat. I asked them if this WAS the price, since the last place - one guy on the phone gave me the same quote.. but when I went in - with nothing extra - quoted me 110 extra. I told this shop they just looked at it, etc.
    This place recommended I bring it in. Cost will be 189 AND they will do a pressure test, etc... so I feel more comfortable about spending the dough if I need to. Will let you know what I find out.
    Thanks again.
  13. Remove Advertisements
