heat issues!!!! - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 21 of 21
HT4100 4.1, 4.5, 4.9 Discussion, heat issues!!!! in Cadillac Engine Discussion; If all three hoses are the same temperature, it means no heat was taken from the heater core. The core ...
  1. #16
    HUF's Avatar
    HUF
    HUF is offline Cadillac Owners Connoisseur
    Automobile(s): 1995 FWB 100,*** miles CURRENT. 1991 Seville 175,000 SOLD
    Dec 2005
    MA
    58
    2,112
    Re: heat issues!!!!
    If all three hoses are the same temperature, it means no heat was taken from the heater core. The core has plastic side tanks. Two fittings are attached to the same side tank. Probably the coolant takes a shortcut through that side tank.
  2. #17
    ehall's Avatar
    ehall is offline Cadillac Owners Connoisseur
    Automobile(s): 1985 Sedan DeVille
    Aug 2007
    Southern Maryland
    1,883
    Re: heat issues!!!!
    It's not that hard to replace the heater core btw. It's a two-hour job for a trained mechanic and a four-hour job for joe shadetree. Mine blew out a little while ago and I found a good writeup in the FWD forum with a search, although I've lost it since (I had the mechanic do it).
  3. #18
    behind-bars is offline Cadillac Owners Connoisseur
    Automobile(s): 93 Sedan Deville 4.9L
    Sep 2005
    Texas
    1,005
    Re: heat issues!!!!
    Quote Originally Posted by HUF View Post
    Ok, so they shouldnt be the same temp. Makes sense, Guess my heater core is probably bad, just not leaking. Do you think its repairable if its shortcutting (could it just be another blockage) or should I just take it out and replace it.If I go the replacement route i guess i will try and save all the cooolant I can since its new.
    Thanks for the help
    I have a FSM for a 4100 engine so I may look at it if i cna find it fora adiagnostic prrocedure and instructions on how to replace the core, if i cant find it in a search.
  5. #19
    nycnftm is offline Cadillac Owners Fanatic
    Automobile(s): 1983 Eldorado
    Jan 2008
    101
    Re: heat issues!!!!
    I just had my heater core bypassed today. You can wear a warm coat while driving and hope the groundhog saw his shadow . Much easier & cheaper than replacing (save your $ for next repair).
  6. #20
    Sep 2005
    Texas
    1,005
    Re: heat issues!!!!
    Quote Originally Posted by nycnftm View Post
    Well if the groundhog saw its shadow it means summer is on the way here in Texas, Which brings us to the next issue, My A/C doesnt work Thats a story for another thread though, But luckily I know solution to that one already
  7. #21
    HUF's Avatar
    HUF
    Dec 2005
    MA
    58
    2,112
    Re: heat issues!!!!
    Quote Originally Posted by behind-bars View Post
    Thanks for the help
    Yeah...I would just replace it with aftermarket core. I got mine for $30, all metal. After flushing my core it started leaking from the gasket between a side tank and the core... Replacing the heater core is not very fun. Too less room. Pay attention HOW you remove stuff from under the dash to put it back in the SAME way just in reverse.
  8. Remove Advertisements
