4.9 and spark knock
Results 1 to 5 of 5
HT4100 4.1, 4.5, 4.9 Discussion, 4.9 and spark knock in Cadillac Engine Discussion; does anyone know much about spark knock on the 4.9? ive had it for the longest time now.......
    Brizzal's Avatar
    Brizzal is offline Cadillac Owners Enthusiast
    Aug 2007
    West Palm Beach, FL
    28
    847
    4.9 and spark knock
    cadillac_al is offline Cadillac Owners Connoisseur
    Automobile(s): 70 Deville 77 Fleet 78 Seville 92 Deville 03 Deville
    Feb 2007
    Maine
    55
    3,310
    Re: 4.9 and spark knock
    Is the EGR system clean? Do you think it could be running hot? I run regular fuel in mine and it never knocks. Maybe I'm losing power and the computer is retarding the timeing but she never knocks and has plenty of pep.
    awadecki is offline Cadillac Owners Enthusiast
    Automobile(s): 76 Eldo (54k), 76 Eldo (52k), 78 Eldo (9k), 85 Deville (43k)
    Jun 2005
    Michigan
    668
    The computer won't retard the timing on 4.9s, there is no knock sensor. Cadillac al, your timing is probably conservatively set.
    Brizzal, your EGR valve is probably sticking closed. Push up on the underside of the diaphram and see if it moves. If it doesn't, you'll need to replace the valve.
    Brizzal's Avatar
    Aug 2007
    West Palm Beach, FL
    28
    847
    any pics on what the egr looks like or where it is? ive never worked on it before. thanks
    HUF's Avatar
    HUF
    HUF is offline Cadillac Owners Connoisseur
    Automobile(s): 1995 FWB 118,*** miles
    Dec 2005
    MA
    58
    2,132
    Quote Originally Posted by Brizzal View Post
    Behind Throttle Body , looks like 3" diameter mushroom with a vacuum line attached to it. Please search the archives for EGR , knock, etc. Tons of info. May be a lot of things besodes the EGR valve. Look for vacuul leaks as well clogged EGR tubes inside the trottle body, under the plates.
  8. Remove Advertisements
