C bieng displayed
Results 1 to 3 of 3
HT4100 4.1, 4.5, 4.9 Discussion, C bieng displayed in Cadillac Engine Discussion; 1992 4.9 a "C" is being displayed on both my climate center and fuel center and my check engine light ...
    wpj
    wpj is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Jan 2008
    3
    C bieng displayed
    1992 4.9 a "C" is being displayed on both my climate center and fuel center and my check engine light is on i have no other displays or control of my heat or fuel settings any ideas???
    urbanski is offline Cadillac Owners 10000+ Posts
    Automobile(s): 05 CTS-V
    Mar 2003
    San 'tone, TX
    23,163
    Re: C bieng displayed
    sorry i locked this, didnt read it right
    Best Car Insurance | Auto Protection Today | FREE Trade-In Quote
    noahsdad's Avatar
    noahsdad is offline Cadillac Owners Connoisseur
    Automobile(s): '87 SDV
    Jun 2005
    Michigan
    57
    1,296
    A "C" display in both the CCP and FDC indicates a break in the circuit between the BCM/Programmer/CCP - FDC.
    First locate the programmer. It's about the size of a paperback book, mounted on the vertical under the dash. You'll have to remove the insulation cover on the bottom of the dash to see it. It's easy to spot, because it will have a mass of wires and vacuum hoses running to it. Disconnect the electrical connector from the programmer and turn on the key. If the CCP/FDC displays return to normal, replace the programmer.
    If both displays still show the "C," disconnect the connector on the back of the CCP. If the FDC display returns to normal, replace the CCP. If not, try connecting the CCP and disconnecting the FDC, then check the CCP display.
    If none of this produces a change, there is a short or bad connection between the BCM and programmer, or the BCM is faulty.
