| HT4100 4.1, 4.5, 4.9 This forum is to discuss the newer aluminum block Cadillac engines. | Cadillac Forums: 4.9 stalls
12-24-07, 04:16 AM
|  | Cadillac Owners Fanatic Cadillac(s): 1992 STS | | Join Date: Oct 2006 Location: Detroit Burbs | | | 4.9 stalls I have a 92 STS that runs good, however sometimes when I stop at a light, it stalls. it starts right back up, but I'm wondering what would cause this. I had it checked, and thought it might need a tuneup, but the mechanic said that might not be the case. Any other reasons for this happening? Thx in advance. |
12-24-07, 06:29 AM
|  | Cadillac Owners Fanatic Cadillac(s): 1993 Eldorado Sports Coupe | | Join Date: Nov 2007 Location: Chicago Age: 21 | | | Re: 4.9 stalls I was having a similar problem with my dads 99 grand prix it's rpms would fluctuate up and down and it hatted stop and go traffic and every so often it would stall. So we took it to the shop and they did some thing with the computer replaced a sensor or something. I would recomend having the shop diagnose the problem (probably gonna coast about $280-$315) and you can always spend about 1.75 for a new PCV valve that could also be your problem. |
12-24-07, 09:16 AM
|  | Cadillac Owners Connoisseur Cadillac(s): 1995 FWB 87,*** 1991 Seville 175,000 SOLD | | Join Date: Dec 2005 Location: MA Age: 50 | | | Re: 4.9 stalls Crankshaft position sensor. |
12-25-07, 01:37 AM
| | Cadillac Owners Fanatic Cadillac(s): 92' Eldorado, 97 Catera | | Join Date: Dec 2006 Location: Tennesse | | | Re: 4.9 stalls I agree with Huf. |
12-26-07, 04:14 PM
|  | Cadillac Owners Fanatic Cadillac(s): 1992 STS | | Join Date: Oct 2006 Location: Detroit Burbs | | | Re: 4.9 stalls Where is this sensor located at? On top of the engine block? Is it easy to repair and how much? Thx guys. |
12-27-07, 12:18 AM
| | Cadillac Owners Connoisseur Cadillac(s): Cadillac 78 Seville, 78 Coupe de Ville, 92 Sedan de Ville | | Join Date: Feb 2007 Location: Maine Age: 48 | | | Re: 4.9 stalls No codes? |
02-05-08, 05:56 PM
| | Cadillac Owners Member Cadillac(s): Cadillac | | | | | Re: 4.9 stalls Hey man, i had kinda the same problem except sometimes it would start right back up and sometimes it wouldnt. I replaced my ignition control module and havent had a problem since=) |
02-05-08, 06:19 PM
| | Cadillac Owners Enthusiast Cadillac(s): 76 Eldo Coupe (50k), 76 Biarritz (50k), 85 Deville (43k) | | Join Date: Jun 2005 Location: Michigan | | | Re: 4.9 stalls Probably the ignition control module or hall effect (cam position) sensor. If it stalls suddenly, this is the case. If it stalls because the engine load suddenly increases due to an engaging A/C compressor, it's the ISC motor. |
02-05-08, 07:38 PM
|  | Cadillac Owners Connoisseur Cadillac(s): 1995 FWB 87,*** 1991 Seville 175,000 SOLD | | Join Date: Dec 2005 Location: MA Age: 50 | | | Re: 4.9 stalls Both ICM and hall effect switch are inside the distributor. |
02-08-08, 10:38 PM
| | Cadillac Owners Fanatic Cadillac(s): 1993 Eldorado, 4.9L, 200k miles | | | | | Re: 4.9 stalls If the engine idles at an abnormally slow speed (<500rpm), the ISC may be stuck in a retracted position. Test the ISC under the hood by opening the throttle by hand...the ISC should extend...let the throttle go and the ISC should retract allowing the engine to return to a normal idles speed. Monitor the idle speed digitally via PD11 in the PCM diagnostics.
If the engine idles at a normal speed around 600rpm, then it is likely a bad ICM or hall effect as Huf indicated. ICM = $21 @ AutoZone. AutoZone can test the ICM, but the test may result in a false pass since the ICM may only fail in the higher temperature conditions experienced when installed in the distributor.
| | Cadillac Discussion Tools | | |
Censor is ON | | | |
