how hard is it to drop the oil pan
Results 1 to 5 of 5
HT4100 4.1, 4.5, 4.9 Discussion, how hard is it to drop the oil pan in Cadillac Engine Discussion; just wondering...
    ehall's Avatar
    ehall is offline Cadillac Owners Connoisseur
    Automobile(s): 1985 Sedan DeVille
    Aug 2007
    Southern Maryland
    1,883
    just wondering
    Po Pimp is offline Cadillac Owners Fanatic
    Automobile(s): 92' Eldorado, 97 Catera
    Dec 2006
    Tennesse
    289
    Re: how hard is it to drop the oil pan
    It is faily easy if it is the transverse engine situation. If it is sitting long ways it is some what of a pain in the ass.
    dita0401's Avatar
    dita0401 is offline Cadillac Owners Enthusiast
    Automobile(s): 1993 CDV 102k
    May 2005
    St. Cloud, MN
    31
    982
    It looks to be a cake job. I have to do it in the spring. I dont remember seeing anything that would be in the way.
    Dec 2006
    Tennesse
    289
    It can be a little tricky if it gets hung on the flywheel bolt. Once it is broke free I remember having to hold the crank side tight to the engine, pulling down on rear side (towards the front of the engine) and the tugging down on the rear (rear). Sounds kind of weird but it will make sense if you encounter it clearance problems.
    On later models 4.9L engines depending on the model the exhaust may run over the pan. The Y pipe will have to be removed. It seems like on the 4.1L there was an air tube or something that had to be removed. Other then the two above it is a straight shoot besides the flywheel dust cover.
    ewill3rd is offline Cadillac Technician
    Automobile(s): none
    Nov 2005
    WOODBRIDGE, VA
    49
    11,051
    It is pretty easy to get the 4.9 pan off, can't speak for the others.
    Taking it off the first time you have to be careful, I remove the oil pump with the pan, then you just grind down the two ears on the back of the pan and put the oil pump back on. Put it all back together and with that small amount ground off the pan it will slide right in.
  8. Remove Advertisements
