Go Back   Cadillac Owners Group > General Discussion > Cadillac Engine Technical Discussion > HT4100 4.1, 4.5, 4.9
HT4100 4.1, 4.5, 4.9 This forum is to discuss the newer aluminum block Cadillac engines.
Cadillac Forums: HT4100 Recommended Oil Viscosity
  #16 (permalink)
Old 12-13-07, 05:05 PM
caddeville's Avatar
Cadillac Owners Enthusiast
View caddeville's Photo Album
Casino Cash: $1065
Re: HT4100 Recommended Oil Viscosity
not ALL 4100's in the FWD cars had coolant in oil, my 4100 exhaust sounds pretty raspy and raw, if my lobes were rounded off, it would sound soft and drowny. My next oil change i am going to switch to Rotella-T 15w40, and run seafoam prior to clean it out a little more because my lifters have a sticky tick or its my valves. Still my caddy has very good power so i think i am ok.
  #17 (permalink)
Old 12-19-07, 10:34 PM
ht4100's Avatar
Cadillac(s): 86 Seville 86 Z28- 95 Grand prix
View ht4100's Photo Album
Casino Cash: $470
You're right about the ZDDP content in current oils for use with flat-tappet camshafts. Last year, I built a 383 stroker for my 86 Camaro. I bought flat-tappet cam from comp cams and they recommend the use of Rotella T oil to properly lubricate the cam because of it's ZDDP content. There is also an article on this in HOT ROD magazine that goes in depth about it. Since I would assume the HT4100 has a flat-tappet cam, and with it's tendency to wear cams out, it would not be a bad idea to use Rotella T, although they have reformulated it in late 2006-early 2007 to contain less ZDDP, so who knows if it's good enough now. A bottle of Cam-break in, or engine oil supplement from your GM dealer would probably be a good idea to run in an HT4100 engine. I probably will start running it in mine also. I can also get Rotella T 10w-30 at a few shops here in town.
Tags: , , ,
ht4100, oil, recommended, viscosity
