Won't start when hot (intermittent)
Results 1 to 7 of 7
HT4100 4.1, 4.5, 4.9 Discussion, Won't start when hot (intermittent) in Cadillac Engine Discussion; Our 93 SDV with 4.9 will occaisionally not start when hot. Wait till completely cold and it starts and runs ...
    tco43 is offline Cadillac Owners Member
    Jan 2004
    81
    UnhappyWon't start when hot (intermittent)
    Our 93 SDV with 4.9 will occaisionally not start when hot. Wait till completely cold and it starts and runs fine. Good for several days. Then re-occured more recently. Re-started after 20 minutes and drove 4 blocks and stalled while running. Previous problems were only a no-start hot. This was a stall while running.Went back after 4 hours and it started and ran normally. The only code it shows is 12 - No Distributor Signal. The car runs again now, expecting it to re-occur. How do I avoid throwing a whole string of parts at it to fix this? Thanks for any help.
    NickySantoro is offline Cadillac Owners Fanatic
    Automobile(s): 1993 Eldo 4.9 66K miles
    Nov 2005
    Nazi Jerky, libtard central
    368
    Re: Won't start when hot (intermittent)
    It's going to be the ignition module, wiring thereto, or the PCM. Because the problem is most pronounced when hot, best guess is the ignition module.
    FWIW
    YMMV
    awadecki is offline Cadillac Owners Enthusiast
    Automobile(s): 76 Eldo (54k), 76 Eldo (52k), 78 Eldo (9k), 85 Deville (43k)
    Jun 2005
    Michigan
    668
    On these engines, it's likely the hall effect sensor (I think the module was gone by 1991 or so, but I could be wrong).
    HUF's Avatar
    HUF
    HUF is offline Cadillac Owners Connoisseur
    Automobile(s): 1995 FWB 100,*** miles CURRENT. 1991 Seville 175,000 SOLD
    Dec 2005
    MA
    58
    2,109
    I would replace the distributor instead of playing with it's components.
    Nov 2005
    368
    Quote Originally Posted by awadecki View Post
    Ignition module was used in all the 4.X engines. Don't know about the Ns, never will.
    Jan 2004
    81
    Thumbs upRe: Won't start when hot (intermittent)
    Autozone lists the
    Ignition module for 19.99,
    the pickup coil for 40.99, and
    the Hall effect switch for 43.99.
    They say the module can be changed in the car, but the distributor has to come out to change the other two, so I'm going to start with the module as the first step.
    Thanks for your help here. Appreciate it.
    Nov 2005
    368
    Be aware that here have been posts here and there about premature failure of AZ modules. When my original module failed, mercifully right in the driveway, I replaced it with a Standard Products brand as it was Sunday and that was all there was available. OK so far after about three years.
    FWIW
    YMMV
  10. Remove Advertisements
