swap 4.1 to a 4.5 or 4.9 in 85 Seville?
Results 1 to 7 of 7
HT4100 4.1, 4.5, 4.9 Discussion, swap 4.1 to a 4.5 or 4.9 in 85 Seville? in Cadillac Engine Discussion; OK, I posted this in the Seville section, but thought this might be a better spot for it. I know ...
    cadmat's Avatar
    cadmat is offline Cadillac Owners Fanatic
    Automobile(s): 1988 Allante.
    Feb 2005
    vista, california
    189
    OK, I posted this in the Seville section, but thought this might be a better spot for it. I know this is kind of an odd question, especially since so few of us seem to care about this model ..but I'm thinking about getting a bustleback Seville, I know the 80 is the best for engine, but I prefer the looks and equipment of the 82- 85, plus, of the few I see that are still around, I see most of those years.. here's my question.. is it an easy swap to put a 4.5 or 4.9 engine into this car? , particularly an Allante 4.5? ( 89 to 92) or just a seville or eldo engine from the late 80'S ? my thinking is the added horsepower and the fact that most of the bugs were worked out by this time would make this engine a good upgrade..What do you think?
    ehall's Avatar
    ehall is offline Cadillac Owners Connoisseur
    Automobile(s): 1985 Sedan DeVille
    Aug 2007
    Southern Maryland
    1,883
    Re: swap 4.1 to a 4.5 or 4.9 in 85 Seville?
    From what I understand (which is probably wrong) the 4.5 can go into any transverse mount 4.1, but those only started in 85.
    awadecki is offline Cadillac Owners Enthusiast
    Automobile(s): 76 Eldo (54k), 76 Eldo (52k), 78 Eldo (9k), 85 Deville (43k)
    Jun 2005
    Michigan
    668
    The 85 seville is a longitundinally-mounted FWD car. Swapping in a 4.5 or 4.9 really isn't feasible. Too many transverse engine differences, and you'd need a new computer and wiring harness. What would be feasbile is for you to find a 6.0L from a 1980 or 1981 Seville, a 5.7L Olds FI V8 from a 1979 Eldorado, or just a plain, old Olds 350 V-8 engine. You might even be able to swap a 425 ci or 500 ci Cadillac V-8 from an older Eldorado into your Seville using your current transmission, but you'd need to beef it up. Not sure if the 425 and 500 ci are physically bigger than the 368 ci engine, but some modifications would definitely be necessary.
    cadmat's Avatar
    Feb 2005
    vista, california
    189
    I'm in California, if it didn't come in it when it was new, I can't do it now and use it as a regular driver legally, due to emission laws 82 to 85 only offered the lousy diesel, the 4.1 and the V6( I think)
    bummer
    Jun 2005
    Michigan
    668
    Hmmm. Well, one thing you can do is advance your timing to 12 degrees. That'll give you what feels like a nice power boost. Aside from that, I guess there's not too much you can do given CA's laws.
    Feb 2003
    california
    69
    6,627
    4.5 and 4.9 use completely different engine block castings, wont work! You can however install the throttle body from an 81 Cadillac 8/6/4 368 cu. in. engine that has larger throttle plates, reattach your TPS switch and your injectors from the original and get the one inch spacer from JEGS speed shop for a throttle body Chevy truck engine. The spacer is required to allow the throttle blades to fully open. Then bump timing from 10 to 12. Did this mod years ago on my first 84 Eldo. It would actually chirp the front tires leaving a stop light!!
    Po Pimp is offline Cadillac Owners Fanatic
    Automobile(s): 92' Eldorado, 97 Catera
    Dec 2006
    Tennesse
    289
    There use to be a couple of places online that sold 4.5L that would mount in this situation. You could not use the MPFI system. This system was built with the 4T60-E in mind, which is electronic. The DFI system would have to be used and you would only see some minimual gains. Well I guess not to minimual the DFI 4.5L was rated at 150 bHP, not sure that you would see the same in a different mount. In the terms you are talking about, junkyard swapping, neither would work as just a drop in conversion.
  10. Remove Advertisements
