Valves too far in advance or too far retarded?
Results 1 to 2 of 2
HT4100 4.1, 4.5, 4.9 Discussion, Valves too far in advance or too far retarded? in Cadillac Engine Discussion; I know that this is a Cadallac forum and I use it for my 1992 Seville, BUT, I have an ...
    forrest Guest
    I know that this is a Cadallac forum and I use it for my 1992 Seville, BUT, I have an urgent problem with my Honda. Trying to get the camshaft syncronized with the crankshaft. You guys are great with engines and the same principles should apply to my problem. My timing belt broke on my 1989 Accord SEI. I guess it's a two liter fuel
    injected. I managed to get it apart and get the new belt on. I got lucky and
    didn't have any bent valves. The problem is figuring out where TDC is, so as
    to be able to synchronize the cam and crank shafts. I have three books and
    none of them show what the actual marks look like. Looking through the
    little peep hole at them, I can see on the advanced side about three hash
    marks, one of them red. Then as you go to the retard side there is a (0)
    with no hash mark at all and then farther over to the retard side is another
    mark or so. Why in hell can't they just have TDC and a mark next to it? If
    it wasn't a solo job I guess I could try the stick in the spark plug hole to
    find TDC. I've never done that and am a little afraid of crunching it in the
    cylinder.
    Anywhoooo ... I got it running, set the timing and took it for a drive
    around the block and thought it was OK. I let my son drive it 90 miles to
    school and back this morning. He said that it didn't run right, so I tried
    it out again. It runs like it's way under powered and has a bogging down
    sound when you accelerate, as well as pinging. I guess I'm probably a tooth
    off one way or the other. Any ideas or thoughts on this? Which way too far is it,
    and am I gonna burn the valves up if I let him drive it this way again? Thanks in advance, for any and all
    responses. And I appologize for using this forum but I have to get it running quickly and the Honda forum is pretty dead. Thanks again.
    cadillac_al is offline Cadillac Owners Connoisseur
    Automobile(s): 70 Deville 77 Fleet 78 Seville 92 Deville 03 Deville
    Feb 2007
    Maine
    55
    3,310
    Re: Valves too far in advance or too far retarded?
    If there is no help here, there must be a Honda forum with some real Honda experts. A factory service manual is the best way to work on any car. Haynes and Chiltons are minimal help. I wonder if it may have a slightly bent valve. You might want to check the compression just to see what it is. If the cam itiming is off a little the compression might be low too. I don't know many vehicles that will run being a tooth off but I'm sure it's possible with some cars. Good luck
