4.9 Code 41 Saga Continues!!!
Results 1 to 4 of 4
HT4100 4.1, 4.5, 4.9 Discussion, 4.9 Code 41 Saga Continues!!! in Cadillac Engine Discussion; So I replaced the cam sensor for the 3rd time and now it has a completely different attitude. The code ...
    386 DeVille is offline Cadillac Owners Fanatic
    Automobile(s): 2000 Cadillac Deville
    Oct 2007
    Daytona Beach, FL
    270
    So I replaced the cam sensor for the 3rd time and now it has a completely different attitude. The code 41 has become intermitent, and it idle, it is on, when I rev it up, it goes off, and if I rev too high for too long, the engine cuts off!! What the hell??
    NickySantoro is offline Cadillac Owners Fanatic
    Automobile(s): 1993 Eldo 4.9 66K miles
    Nov 2005
    Nazi Jerky, libtard central
    368
    Re: 4.9 Code 41 Saga Continues!!!
    Inspect the internal distributor wiring carefully, looking for fraying. What you are looking for is an intermittent short to ground.
    Oct 2007
    Daytona Beach, FL
    270
    Well, I have ohmed out the wiring and they all check out fine....?
    Nov 2005
    368
    If you visually inspected for any fraying that could intermittently cause a short to ground while still exhibiting the correct ohms and you flexed the wires while testing to verify that there isn't an internal break that only intermittently causes an open, this is certainly an enigma.
  7. Remove Advertisements
