4100 Newbie needs help!
Results 1 to 6 of 6
HT4100 4.1, 4.5, 4.9 Discussion, 4100 Newbie needs help! in Cadillac Engine Discussion; Hello. I just purchased a 1982 Eldo with 59000 miles and a 4.1 V8. The only problem is that if ...
    Jeff595's Avatar
    Jeff595 is offline Cadillac Owners Member
    Automobile(s): 1982 Cadillac Eldo
    Nov 2007
    NW Iowa
    Hello. I just purchased a 1982 Eldo with 59000 miles and a 4.1 V8. The only problem is that if I drive the car for 15 or 20 minutes, then shut if off for 5 or 10 minutes, it doesn't want to start back up. I let the car sit for a while, and it fires right up and runs ok. It also seems to be real sluggish (surge in and out) while taking off from a stop. The little old lady that I bought the car from took it to the local cadillac dealer to have it looked at for this, but unfortunately for us most of the tech's there are younger than the car and have no idea what to do with something this old! I ran the codes (something they did not know how to do) and only came up with a code 30 (ISC RPM Out of Range). Any suggestions? Thanks.
    Tommy Deville's Avatar
    Tommy Deville is offline Cadillac Owners Enthusiast
    Automobile(s): None
    Jan 2006
    Staten Island NY
    588
    Re: 4100 Newbie needs help!
    I can't elieve there isn't an "old timer" that knows how to work on that model.
    First off 59000 miles on a eldo that old is sweet! how much did u pay?
    2nd it maye a timing issue, possibly need a pickup coil which is part of the distrubtor shaft, or a new distrubtor all together.
    Also, check the cat. convertor.
    Jeff595's Avatar
    Nov 2007
    NW Iowa
    Ya, it is a pretty sweet car, definately rides better than any of the newer stuff I have had. I originally went to look at her all original 75 Monte Carlo with 39000 miles, but was a little more money than I wanted to spend. She said she was also getting rid of her "daily" car, because it had been running funny. She was more than happy to just get $1000 out of it so she didn't have to insure it when she went away for the winter!
    I guess I haven't even looked, but do you happen to know what the timing should be on these? Also, why would the cat cause these problems, and how would I know if it was bad or not? I have been under the car a couple of times, at it is as clean as the top save for a minor amount of fluid on the tranny pan. Guess I am just not sure what I should be looking for with the cat. Thanks for the help.
    Automobile(s): None
    Jan 2006
    Staten Island NY
    588
    not sure what the timing is........you said there is a surge & lack of power, a clogged cat would cause that, get the car nice & hot and have some one give it gas in park, check under the car, if the cat is bad it will be glowing red.
    also, clear the codes see if they reoccur, may need to change the sensor that was throwing the codes.
    awadecki is offline Cadillac Owners Enthusiast
    Automobile(s): 76 Eldo (54k), 76 Eldo (52k), 78 Eldo (9k), 85 Deville (43k)
    Jun 2005
    Michigan
    668
    OK, let's start with the easy stuff first.
    1. Check the timing. Base should be set at 10 degrees (see the emissions label under your hood for the timing procedure).
    2. More than likely, your EGR valve is sticking open and causing the E30 (the ISC is extending too far, trying to keep the RPMs up at idle). Push up on the underside diaphram on the EGR. If it moves freely, it's OK, if not, it must be replaced. This will also cause hesitation, sag, and reduced power, and starting problems.
    Also, try this. Next time your car is warm and it won't start, take a metal wrench or hammer, and tap the EGR valve about 10 times. This will free a stuck diaphram. They tend to stick more when hot. Then try to start the car. If it starts, the EGR is bad.
    3. Plugged catalytic converter will cause a loss of engine power. Too much backpressure, but worry about 1) and 2) first.
    wikked_magick45 is offline Cadillac Owners Member
    Automobile(s): Cadillac Seville 4.9L
    Oct 2007
    Saginaw, MI
    24
    I had a 4.1 in an 86 DeVille, it was slower than shit and I cut the cat off and put a cherry bomb in it's place and it came back to life!
  9. Remove Advertisements
