She runs!
Results 1 to 2 of 2
HT4100 4.1, 4.5, 4.9 Discussion, She runs! in Cadillac Engine Discussion; After much money and time, the '92 Deville 4.9 now runs amazingly. Turns out, we DID get a bad ECM ...
    Bluenose1 is offline Cadillac Owners Member
    Automobile(s): 97 Seville STS
    Nov 2006
    22
    TalkingShe runs!
    After much money and time, the '92 Deville 4.9 now runs amazingly. Turns out, we DID get a bad ECM from the after market place. Bought one from GM and all is well. In fact, we are gonna stick with GM parts, I think. Cadillacs are particular.
    Anyway, we had a minor fuel line leak and are replacing the tank, because of the problem with the broken baffles. We'd been putting it off, but since we had a leak, just figured we'd go ahead and fix it. You can see the broken plastic bits there. The new tank has no plastic.
    The ABS light has been coming on, we think that perhaps the leaking fuel line (by the left rear tire) may have been causing fuel to make the sensor mess up. Only time will tell if that theory is correct, since the new tank replacement is going slowly due to time constraints.
    Otherwise, this car remains a joy to drive. The body and interior are still in amazing condition. Nothing beats a nice big comfy Caddy.
    caddydaddy's Avatar
    caddydaddy is offline Cadillac Owners Connoisseur
    Automobile(s): 2005 Escalade 6.0L 2WD, 2007 Jeep Grand Cherokee Limited CRD
    Jan 2003
    Gales Ferry, CT
    35
    3,717
    Re: She runs!
    Glad to hear that! I've pretty much had bad luck as well with aftermarket parts as well. I try and buy GM parts when I can.
