poor gas milage
Results 1 to 7 of 7
HT4100 4.1, 4.5, 4.9 Discussion, poor gas milage in Cadillac Engine Discussion; hope this is the right place. i have a 95 cadillac sedan deville 4.9l engine,i recently replaced the the engine ...
    cadillaceldorado is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Dec 2006
    14
    poor gas milage
    hope this is the right place. i have a 95 cadillac sedan deville 4.9l engine,i recently replaced the the engine with a remanufactured one(3yr unlimited milage),right after installation there was a problem with the nuimber 5 cylinder(oil and antifreeze leaking in) the heads were replaced and the car runs find now.however the gas milage is very poor(new wires,plugs,egr valve,o2 sensors,gas ,oil,air radiator,distributor,rotor,water pump were put in) on expressway i get 20mpg,but just driving around city it drops down to 7.9mpg any ideas to my promblem,the engine has 1200miles. also the idle is some time up and down but it never does it when i'm at the mechanic
    awadecki is offline Cadillac Owners Enthusiast
    Automobile(s): 76 Eldo (54k), 76 Eldo (52k), 78 Eldo (9k), 85 Deville (43k)
    Jun 2005
    Michigan
    668
    Re: poor gas milage
    Possibly bad FPR, or a leaking injector. If you had a reman engine put in, they simply removed the fuel rail and reinstalled it, so even though your engine is new, your FPR and injectors are old.
    4.9s eat factory injectors. I'd bet one is bad. Do a balance test using the onboad ECM overrides.
    Dec 2006
    14
    Re: poor gas milage
    thanks for the info. how do you do the balance test,what is the FPR?,and should i replace all the injectors or will the balance test tell me which one is bad?
    Dec 2006
    14
    Re: poor gas milage
    Quote Originally Posted by awadecki View Post
    love the car but not a mechanic.thanks for the info.what is the FPR (fuel pressure rail?),how do i do balance test? injectors are $90.00 ea. do i have to replace all?
    Jun 2005
    Michigan
    668
    Re: poor gas milage
    FPR=fuel pressure regulator. First, pull the vacuum hose off of it (it's a black, round thing next to the throttle body, attached to the fuel rail) and spray in the nipple with WD-40, lots of WD-40. Then, reconnect the vacuum hose and blip the throttle about 15 times and drive the car around. See if that helps.
    You don't need to replace all the injectors. Do a search here on how to perform a balance test--I'm too tired to type it all out.
    Basically, you hit a couple of buttons on the dash, and you can cycle through each cylinder and shut off an injector. While doing this, you measure the RPM drop on the cylinder. If the RPM drop on one cylinder is a lot less than on the others, you have a leaking injector.
    Dec 2006
    14
    Re: poor gas milage
    thank your the best will let you know how it turned out
    NickySantoro is offline Cadillac Owners Fanatic
    Automobile(s): 1993 Eldo 4.9 66K miles
    Nov 2005
    Nazi Jerky, libtard central
    368
    Re: poor gas milage
    In light of the two symptoms you relate, you might wish to check the timing to see if it is retarded as well as cleaning the throttle body and blades.
  10. Remove Advertisements
